Updated on 2025-01-09 GMT+08:00
RENAME TABLE
Function
The ALTER TABLE ... RENAME command is used to change the table name.
Syntax
ALTER TABLEtableName RENAME TO newTableName
Parameter Description
Table 1 RENAME parameters
tableName
Table name.
newTableName
New table name.
Required Permissions
  • SQL permissions
Table 2 Permissions required for executing ALTER TABLE
Permission Description
ALTER permission on a table
  • Fine-grained permission: dli:table:alter
  • Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
Example
ALTER TABLE table1 RENAME TO table2
Response
You can run the SHOW TABLES command to view the new table name.
