Halaman ini belum tersedia dalam bahasa lokal Anda. Kami berusaha keras untuk menambahkan lebih banyak versi bahasa. Terima kasih atas dukungan Anda.
Kubernetes 1.17 (EOM) Release Notes
CCE has passed the Certified Kubernetes Conformance Program and is a certified Kubernetes offering. This section describes the updates in CCE Kubernetes 1.17.
Resource Changes and Deprecations
  • All resources in the apps/v1beta1 and apps/v1beta2 API versions are no longer served. Migrate to use the apps/v1 API version.
  • DaemonSets, Deployments, and ReplicaSets in the extensions/v1beta1 API version are no longer served. You can use the apps/v1 API version.
  • NetworkPolicies in the extensions/v1beta1 API version are no longer served. Migrate to use the networking.k8s.io/v1 API version.
  • PodSecurityPolicies in the extensions/v1beta1 API version are no longer served. Migrate to use the policy/v1beta1 API version.
  • Ingresses in the extensions/v1beta1 API version will no longer be served in v1.20. Migrate to use the networking.k8s.io/v1beta1 API version.
  • PriorityClass in the scheduling.k8s.io/v1beta1 and scheduling.k8s.io/v1alpha1 API versions is no longer served in v1.17. Migrate to use the scheduling.k8s.io/v1 API version.
  • The event series.state field in the events.k8s.io/v1beta1 API version has been deprecated and will be removed from v1.18.
  • CustomResourceDefinition in the apiextensions.k8s.io/v1beta1 API version has been deprecated and will no longer be served in v1.19. Use the apiextensions.k8s.io/v1 API version.
  • MutatingWebhookConfiguration and ValidatingWebhookConfiguration in the admissionregistration.k8s.io/v1beta1 API version have been deprecated and will no longer be served in v1.19. You can use the admissionregistration.k8s.io/v1 API version.
  • The rbac.authorization.k8s.io/v1alpha1 and rbac.authorization.k8s.io/v1beta1 API versions have been deprecated and will no longer be served in v1.20. Use the rbac.authorization.k8s.io/v1 API version.
  • The CSINode object of storage.k8s.io/v1beta1 has been deprecated and will be removed in later versions.
Other Deprecations and Removals
  • OutOfDisk node condition is removed in favor of DiskPressure.
  • The scheduler.alpha.kubernetes.io/critical-pod annotation is removed in favor of priorityClassName.
  • beta.kubernetes.io/os and beta.kubernetes.io/arch have been deprecated in v1.14 and will be removed in v1.18.
  • Do not use --node-labels to set labels prefixed with kubernetes.io and k8s.io. The kubernetes.io/availablezone label in earlier versions is removed in v1.17 and changed to failure-domain.beta.kubernetes.io/zone.
  • The beta.kubernetes.io/instance-type is deprecated in favor of node.kubernetes.io/instance-type.
  • Remove the {kubelet_root_dir}/plugins path.
  • Remove the built-in cluster roles system:csi-external-provisioner and system:csi-external-attacher.
References
For more details about the performance comparison and function evolution between Kubernetes 1.17 and other versions, see the following documents:
Kami menggunakan cookie untuk meningkatkan kualitas situs kami dan pengalaman Anda. Dengan melanjutkan penelusuran di situs kami berarti Anda menerima kebijakan cookie kami. Cari tahu selengkapnya
