El contenido no se encuentra disponible en el idioma seleccionado. Estamos trabajando continuamente para agregar más idiomas. Gracias por su apoyo.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Help Center/
Cloud Operations Center/
User Guide/
Faults/
WarRoom/
Adding a War Room Initiation Rule
Create a war room initiation rule.
- Log in to COC.
- In the navigation pane on the left, choose Incident Management > WarRoom. Click WarRoom Rules.
Figure 1 War room rules
- Click Create WarRoom Rule. In the displayed dialog box, set the rule name, region, application, incident level, and group information, and click OK.
The war room rule matching logic: The region, application, and level of an incident will match with those of a war room rule, and the personnel in the group will be added to the war room and the mobile app. For details about how to configure the mobile app, see Mobile App Management.Figure 2 Adding a war room rule
- After the rule is created, query the new rule in the rule list.
Parent topic: WarRoom
