El contenido no se encuentra disponible en el idioma seleccionado. Estamos trabajando continuamente para agregar más idiomas. Gracias por su apoyo.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Help Center/
Cloud Operations Center/
User Guide/
Faults/
Incident Management/
Handling an Incident/
Creating an Improvement Ticket For An Incident
If an improvement item is found during the handling of an incident ticket, you can create an improvement ticket to follow up the handling.
An improvement ticket can be created only after the incident is accepted.
- Log in to COC.
- In the navigation pane on the left, choose Incident Management > Incident Center. On the displayed page, click the Pending tab and click the incident title to go to the incident details page.
- On the right of the page, click
and choose Create Improvement Order. On the displayed page, enter improvement information and click OK.
Figure 1 Creating an improvement ticketFigure 2 Entering improvement ticket information - View the improvement ticket status and current owner on the improvement record page. You can also click the improvement task name to go to the improvement management page to handle the improvement ticket.
Figure 3 Viewing improvement record
Parent topic: Handling an Incident
