Overview
The Scheduled O&M page displays details and execution records of all scheduled tasks. You can create and manage scheduled tasks on this page. After scheduled tasks are created, operations (such as script execution and job management) are performed at a specified time or periodically.
Scheduled O&M includes the following key elements:
- Scheduled Type: One-time execution and periodic execution (including simple execution or cron expression).
- Task Type: Scripts and Jobs.
- Executed By: Select as required for the target instance.
Restrictions on Scheduled O&M
- Each account can create a maximum of 200 scheduled tasks.
- The target instance can be an ECS, FlexusL, or BMS instance.
- For a scheduled task, only when the Status is Normal (for the task that does not need to be approved or has passed the approval) and Enabled Status is Enabled, the scripts or jobs can be automatically executed.
