Help Center>
Cloud Container Engine>
User Guide (ME-Abu Dhabi Region)>
Node Pools>
Managing a Node Pool>
Copying a Node Pool
Updated on 2024-01-04 GMT+08:00
Copying a Node Pool
You can copy the configuration of an existing node pool on the CCE console to create new node pools.
- Log in to the CCE console.
- Click the cluster name to access the cluster console. Choose Nodes in the navigation pane and click the Node Pools tab on the right.
- Locate the target node pool and choose More > Copy in the Operation column.
- In the displayed dialog box, the configurations of the selected node pool are displayed. You can modify the configurations as needed. For details, see Creating a Node Pool. After confirming the configuration, click Next: Confirm.
- On the Confirm page, confirm the node pool configurations and click Submit. Then, a new node pool is created based on the modified configurations.
Parent topic: Managing a Node Pool
