Updated on 2025-12-12 GMT+08:00
Overview of Server-Side Encryption APIs
You can use APIs to configure encryption for existing buckets, as well as obtain and delete encryption configuration of existing buckets. For details, see Configuring Bucket Encryption, Obtaining Bucket Encryption Configuration, and Deleting the Encryption Configuration of a Bucket.
You can also configure encryption in the APIs for creating a bucket, uploading, downloading, and copying an object, as well as uploading an object in a multipart upload. The following table lists these APIs and parameters involved.
Table 1 Server-side encryption APIs and parameters
Type
Header
API for Creating a Bucket
API for Uploading an Object - PUT
API for Uploading an Object - POST
Request headers
x-obs-server-side-encryption
Specifies the encryption method.
kms: SSE-KMS is used for encryption.
obs: SSE-OBS is used for encryption.
AES256: SSE-OBS and the AES-256 algorithm are used.
x-obs-server-side-data-encryption
Specifies the algorithm used for server-side encryption.
AES256: The AES-256 algorithm is used. AES-256 can be used for both SSE-KMS and SSE-OBS.
SM4: The SM4 algorithm is used. SM4 can only be used for SSE-KMS.
If this header is not included, the AES-256 algorithm is used.
x-obs-server-side-encryption-kms-key-id
Specifies the ID of the KMS CMK when SSE-KMS is used.
Key ID
Key ID
Key ID
x-obs-sse-kms-key-project-id
Specifies the ID of the project to which the KMS CMK belongs when SSE-KMS is used.
Project ID
x-obs-server-side-encryption-customer-algorithm
Specifies the algorithm for SSE-C.
AES256: SSE-C and the AES-256 algorithm are used.
x-obs-server-side-encryption-customer-key
Specifies the plaintext key encoded in Base64 when SSE-C is used.
The plaintext key encoded in Base64
x-obs-server-side-encryption-customer-key-MD5
Specifies the MD5 value of the key when SSE-C is used.
The Base64-encoded MD5 value of the key
x-obs-copy-source-server-side-encryption-customer-algorithm
Specifies the algorithm for object copies when SSE-C is used.
x-obs-copy-source-server-side-encryption-customer-key
Specifies the Base64-encoded key for object copies when SSE-C is used.
x-obs-copy-source-server-side-encryption-customer-key-MD5
Specifies the MD5 value of the key used for object copies when SSE-C is used.
Response headers
Specifies the server-side encryption method.
The key ID is returned only for custom keys.
The key ID is returned for both default keys and custom keys.
The project ID is returned only for custom keys.
Specifies the Base64-encoded MD5 value of the key when SSE-C is used.
Table 2 Server-side encryption APIs and parameters
Type
Header
API for Copying an Object
API for Initiating a Multipart Upload
API for Uploading Parts
API for Copying Parts
API for Completing a Multipart Upload
Request headers
Key ID
AES256: The target object copy is encrypted using SSE-C and the AES-256 algorithm.
Specifies the Base64-encoded MD5 value of the key used for object copies when SSE-C is used.
Response headers
Key ID
Table 3 Server-side encryption APIs and parameters
Type
Header
API for Downloading an Object
API for Querying Object Metadata
Request headers
Response headers
Key ID
