Updated on 2025-07-01 GMT+08:00
Using Logging to Record OBS Logs
After logging is enabled for a bucket, OBS automatically converts bucket logs into objects following the naming rules and writes the objects into a target bucket.
You can enable logging to facilitate analysis or audit. Access logs enable a bucket owner to analyze the property, type, or trend of requests to the bucket in depth. When the logging function of a bucket is enabled, OBS will log access requests for the bucket automatically, and write the generated log files to the specified bucket (target bucket).
You need to specify a bucket for storing log files when enabling logging for a bucket. Log files can be stored in any bucket in the region where the logged bucket resides, including the logged bucket itself. To better manage logs, you are advised to store log files in a bucket other than the logged bucket. If log files are stored in the logged bucket, OBS creates additional logs for writing log files to the bucket, which takes up extra storage space that will increase your costs and makes it more difficult for you to locate required logs.
  • Uploading bucket logs to the target bucket incurs billable PUT requests. For details about the pricing, see Requests.
After logging is enabled, the log delivery user group will be automatically granted the permission to read the bucket ACL and write the bucket where logs are saved. If you manually disable such permissions, bucket logging will fail.
OBS can log bucket access requests for further request analysis or log audit.
Logs occupy the OBS storage that incurs costs, so OBS does not collect bucket access logs by default.
OBS creates log files and uploads them to a specified bucket. To perform these operations, OBS must be granted required permissions. Therefore, before configuring logging for a bucket, you need to create an IAM agency for OBS and add this agency when configuring logging for the bucket. By default, when configuring permissions for an agency, you only need to grant the agency the permission to upload log files (PutObject) to the bucket for storing log files. In the following example, mybucketlogs is the bucket. If the log storage bucket has server-side encryption enabled, the agency also requires the KMS Administrator permission for the region where the bucket is located.
    "Version": "1.1",
    "Statement": [
            "Action": [
                "obs:object:PutObject"
            "Resource": [
                "OBS:*:*:object:mybucketlogs/*"
            "Effect": "Allow"
After logging is configured, you can view operation logs in the bucket that stores the logs in approximately fifteen minutes.
The following shows an example access log of the target bucket:
787f2f92b20943998a4fe2ab75eb09b8 bucket [13/Aug/2015:01:43:42 +0000] xx.xx.xx.xx
787f2f92b20943998a4fe2ab75eb09b8 281599BACAD9376ECE141B842B94535B  REST.GET.BUCKET.LOCATION
- "GET /bucket?location HTTP/1.1" 200 - 211 - 6 6 "-"  "HttpClient" - -
The access log of each bucket contains the following information.
Table 1 Bucket log format
Name
Example
BucketOwner
Account ID of the bucket owner
Bucket
bucket
Name of the bucket
Time
Timestamp of the request (UTC)
Remote IP
xx.xx.xx.xx
IP address from where the request is initiated
Requester
Requester ID
  • When an account initiates a request, this parameter value is the account ID. When an IAM user initiates a request, this parameter value is the ID of the account where the IAM user belongs.
  • When an anonymous user initiates a request, this parameter value is Anonymous.
RequestID
Request ID
Operation
Name of the operation
See Table 2 for common operations and their description.
Key
Object name
Request-URI
URI of the request
HTTPStatus
200
Response code
ErrorCode
Error code
BytesSent
211
Size of the HTTP response, expressed in bytes
ObjectSize
Object size (bytes)
  • When OBS deletes an object, it does not log the object's size. In the object deletion log, the value of ObjectSize is 0.
  • If error code 4XX is returned, the value of ObjectSize is -, indicating that the specific object size is not displayed.
TotalTime
6
Processing time on the server (ms)
Turn-AroundTime
6
Total time for processing the request (ms)
This parameter can also be written as TotalTime.
Referer
Header field Referer of the request
User-Agent
HttpClient
User-Agent header of the request
VersionID
Version ID carried in the request
STSLogUrn
Federated authentication and agency information
StorageClass
STANDARD_IA
Current storage class of the object
TargetStorageClass
GLACIER
Storage class that the object will be transited to
DentryName
12456/file.txt
  • For a parallel file system, this field indicates an internal identifier of a file or directory. Its value consists of a parent directory inode number and a file or directory name.
  • For a bucket, the value of this field is -.
IAMUserID
8f3b8c53d29244a780084f2b8c106c32
ID of an IAM user.
When a request is initiated by an anonymous user, Anonymous is logged.
Table 2 Common operations
Operation
Operation
REST.GET.SERVICE
Lists buckets.
REST.GET.ENCRYPTION
Obtains the bucket encryption configuration.
REST.PUT.BUCKET
Creates a bucket.
REST.DELETE.ENCRYPTION
Deletes the bucket encryption configuration.
REST.HEAD.BUCKET
Views the bucket information.
REST.PUT.OTM_DIRECT_COLD_ACCESS
Configures direct reading for Archive objects in a bucket.
REST.GET.BUCKETVERSIONS
Lists objects in a bucket.
REST.GET.OTM_DIRECT_COLD_ACCESS
Obtains the direct reading configuration of a bucket.
REST.GET.BUCKET
Obtains the bucket metadata.
REST.DELETE.OTM_DIRECT_COLD_ACCESS
Deletes the direct reading configuration of a bucket.
Obtains the bucket location.
REST.PUT.BUCKET.WEBSITE
Configures static website hosting for a bucket.
REST.DELETE.BUCKET
Deletes a bucket.
REST.GET.BUCKET.WEBSITE
Obtains the static website hosting configuration of a bucket.
REST.PUT.POLICY
Configures a bucket policy.
REST.DEL.BUCKET.WEBSITE
Deletes the static website hosting configuration of a bucket.
REST.GET.POLICY
Obtains a bucket policy.
REST.PUT.BUCKET.CORS
Configures CORS for a bucket.
REST.DELETE.POLICY
Deletes a bucket policy.
REST.GET.BUCKET.CORS
Obtains the CORS configuration of a bucket.
REST.PUT.ACL
Configures an ACL for a bucket or an object.
REST.DEL.BUCKET.CORS
Deletes the CORS configuration of a bucket.
REST.GET.ACL
Obtains a bucket ACL or an object ACL.
REST.OPTIONS.BUCKET
Checks bucket OPTIONS.
REST.PUT.LOGGING_STATUS
Configures logging for a bucket.
REST.OPTIONS.OBJECT
Checks object OPTIONS.
REST.GET.LOGGING_STATUS
Obtains the bucket logging configuration.
REST.PUT.OBJECT
Uploads an object with PUT.
REST.PUT.BUCKET.LIFECYCLE
Configures a bucket lifecycle rule.
REST.POST.OBJECT
Uploads an object with POST.
REST.GET.LIFECYCLE
Obtains the lifecycle configuration of a bucket.
REST.COPY.OBJECT
Copies an object.
REST.DEL.LIFECYCLE
Deletes the lifecycle configuration of a bucket.
REST.GET.OBJECT
Obtains the object content.
REST.PUT.VERSIONING
Configures versioning for a bucket.
REST.HEAD.OBJECT
Obtains the object metadata.
REST.GET.VERSIONING
Obtains the bucket versioning status.
REST.DELETE.OBJECT
Deletes an object.
REST.GET.BUCKET.STORAGE.POLICY
Obtains the default storage class of a bucket.
REST.TRANSITION.STORAGECLASS.OBJECT
Changes the storage class of an object.
REST.PUT.BUCKET.STORAGE.POLICY
Configures the default storage class for a bucket.
OP_MULTIPLE_DELETEOBJECT
Batch deletes objects.
REST.PUT.REPLICATION
Configures cross-region replication for a bucket.
REST.POST.RESTORE
Restores an Archive object.
REST.DELETE.REPLICATION
Deletes the cross-region replication configuration of a bucket.
REST.APPEND.OBJECT
Appends data to an object.
REST.GET.REPLICATION
Obtains the cross-region replication configuration of a bucket.
REST.MODIFY.OBJECT.META
Modifies object metadata.
REST.PUT.TAGGING
Configures tags for a bucket.
REST.TRUNCATE.OBJECT
Truncates an object.
REST.GET.TAGGING
Obtains bucket tags.
REST.RENAME.OBJECT
Renames an object.
REST.DEL.TAGGING
Deletes bucket tags.
REST.GET.UPLOADS
Lists the initiated multipart uploads in a bucket.
REST.PUT.BUCKET_QUOTA
Configures a storage quota for a bucket.
REST.POST.UPLOADS
Initiates a multipart upload.
REST.GET.BUCKET.QUOTA
Queries the bucket storage quota.
REST.PUT.PART
Uploads a part.
REST.GET.BUCKET.STORAGEINFO
Queries the information about the used space in a bucket.
REST.COPY.PART
Copies a part.
REST.PUT.BUCKET.INVENTORY
Configures inventories for a bucket.
REST.GET.UPLOAD
Lists uploaded parts.
REST.GET.BUCKET.INVENTORY
Obtains or lists bucket inventories.
REST.POST.UPLOAD
Assembles parts.
REST.DELETE.BUCKET.INVENTORY
Deletes bucket inventories.
REST.DELETE.UPLOAD
Aborts a multipart upload.
REST.PUT.CUSTOMDOMAIN
Configures a custom domain name for a bucket.
REST.CLEAR.EXPIRE.UPLOAD
Deletes expired segments.
REST.GET.CUSTOMDOMAIN
Obtains the custom domain name of a bucket.
REST.DELETE.CUSTOMDOMAIN
Deletes a custom domain name of a bucket.
REST.PUT.ENCRYPTION
Configures encryption for a bucket.
Ways to Configure Logging for a Bucket
You can use OBS Console, APIs, or SDKs to configure logging for a bucket.
Related Operations
  • Disable bucket logging.
If you no longer need to record logs, in the Logging dialog box, click Disable and then click OK. After logging is disabled, logs are not recorded, but existing logs in the target bucket will be retained.
  • Configure an agency for uploading logs.
