Updated on 2022-09-23 GMT+08:00
Creating a Backup Restoration Task
You can create a backup restoration task on FusionInsight Manager. After the restoration task is executed, the specified backup data is restored to the cluster.
  2. Choose O&M > Backup and Restoration > Restoration Management. On the page that is displayed, click Create.
  3. Configure Task Name.
  4. Set Recovery Object to OMS or the cluster whose data you want to restore.
  5. Set the required parameters in the Recovery Configuration area.
  6. Click OK to save the configurations.
  7. In the restoration task list, you can view the created restoration tasks.
    Locate the row containing the target restoration task, click Start in the Operation column to execute the restoration task immediately.
