Updated on 2022-09-23 GMT+08:00
Managing Backup and Backup Restoration Tasks
You can also maintain and manage backup restoration tasks on FusionInsight Manager.
  2. Choose O&M > Backup and Restoration > Backup Management or Restoration Management.
  3. In the Operation column of the specified task in the task list, select the operation to be performed.
    Table 1 Maintenance and management operations
    Operation Entry
    Modify parameters for the backup task.
    Recover
    After some service data is successfully backed up, you can use this function to quickly restore data.
    More > Back Up Now
    Perform this operation to execute the backup task immediately.
    More > Stop
    Perform this operation to stop a running task.
    More > Delete or Delete
    This operation is used to delete tasks.
    More > Suspend
    Perform this operation to disable the automatic backup task function.
    More > Resume
    Perform this operation to enable the automatic backup task function.
    More > View History or View History
    Perform this operation to switch to the task run log page to view the task running details and backup path.
    View
    Perform this operation to check the parameter settings of the restoration task.
    Start
    Perform this operation to run the restoration task.
