- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Permissions Management
- Elastic IP
- EIP Billing
- EIP Pool
- Shared Bandwidth
- Shared Data Package
- Global EIPs
- Global Internet Gateways
- Global Internet Bandwidths
- Global Connection Bandwidths
- Cloud Eye Monitoring
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
- APIs
- API V3
- Native OpenStack Neutron APIs V2.0
- Application Examples
- Appendix
- SDK Reference
Product Consultation
- Managing Quotas
- How Do I Assign or Retrieve a Specific EIP?
- Why Is an EIP Newly Assigned the Same as the One I Released?
- Can I Buy a Specific EIP?
- Does an EIP Change Over Time?
- Why Can't I Find My Purchased EIP on the Management Console?
- What Is the EIP Assignment Policy?
- Can an EIP Be Used or Migrated Across Accounts?
- How Do I Query the Traffic Usage of My EIP?
- Do I Need to Configure a Shared Data Package for Use After It Is Purchased?
- Can I Change the Dedicated Bandwidth Used by an EIP to a Shared Bandwidth?
- How Many ECSs Can I Bind an EIP To?
- What Are the Differences Between EIP, Private IP Address, and Virtual IP Address?
- What Are the Differences Among a Bandwidth Add-On Package, Shared Data Package, and Shared Bandwidth?
- When Should I Use Premium BGP and Are There Any Limitations on Using Premium BGP?
- Why My EIPs Are Frozen? How Do I Unfreeze My EIPs?
Billing and Payments
- How Is an EIP Billed?
- How Do I Change My EIP Billing Mode Between Pay-per-Use and Yearly/Monthly?
- How Do I Change the Billing Option of a Pay-per-Use EIP Between By Bandwidth and By Traffic?
- Why Am I Still Being Billed After My EIP Has Been Unbound or Released?
- When Will I Be Billed for Reservation Price?
EIP Binding and Unbinding
- How Do I Access an ECS with an EIP Bound from the Internet?
- How Can I Unbind an Existing EIP from an Instance and Bind Another EIP to the Instance?
- Can I Bind an EIP of an ECS to Another ECS?
- Can I Bind an EIP to a Cloud Resource in Another Region?
- Can Multiple EIPs Be Bound to an ECS?
- What Are the Differences Between Unbinding and Releasing an EIP?
Bandwidth
- How Do I Increase a Bandwidth to Be More Than 300 Mbit/s?
- What Bandwidth Types Are Available?
- How Many EIPs Can I Add to Each Shared Bandwidth?
- What Are the Differences Between a Dedicated Bandwidth and a Shared Bandwidth?
- What Are Inbound Bandwidth and Outbound Bandwidth?
- How Do I Know If My EIP Bandwidth Has Been Exceeded?
- What Are the Differences Between Public Bandwidth and Private Bandwidth?
- Can I Increase a Yearly/Monthly Bandwidth and Decrease It Later?
- What Is the Relationship Between Bandwidth and Upload/Download Rate?
- What Are the Differences Among Static BGP, Dynamic BGP, and Premium BGP?
Connectivity
- What Are the Priorities of the Custom Route and EIP If Both Are Configured for an ECS to Enable the ECS to Access the Internet?
- Why Can't My ECS Access the Internet Even After an EIP Is Bound?
- What Should I Do If an EIP Cannot Be Pinged?
- How Do I Unblock an EIP?
- Why Is There Network Jitter or Packet Loss During Cross-Border Communications?
- Why Does the Download Speed of My ECS Is Slow?
- Videos
- Glossary
More Documents
- Quick Start
- EIP Overview
- Assigning an EIP and Binding It to an ECS
- Assigning an EIP
- Binding an EIP to an Instance
- Unbinding an EIP from an Instance
- Releasing an EIP
- Changing Dedicated Bandwidth Size of an EIP
- Unbinding an EIP from an ECS and Releasing the EIP
- Modifying an EIP Bandwidth
- Exporting EIP Information
- Managing EIP Tags
- Shared Bandwidth
- Monitoring
- What Is a Quota?
- Can an EIP That Uses Dedicated Bandwidth Be Changed to Use Shared Bandwidth?
- Can I Bind an EIP to Multiple ECSs?
- What Are the Differences Between the Primary and Extension NICs of ECSs?
- Can I Assign a Specific EIP?
- Can a Bandwidth Be Used by Multiple Accounts?
- How Do I Unbind an EIP from an Instance and Bind a New EIP to the Instance?
- Why Can't I Find My Assigned EIP on the Management Console?
- EIP Binding and Unbinding
Bandwidth
- What Is the Bandwidth Size Range?
- Is There a Limit to the Number of EIPs That Can Be Added to Each Shared Bandwidth?
- How Do I Know If My EIP Bandwidth Limit Has Been Exceeded?
- Connectivity
- Change History
- API Reference (ME-Abu Dhabi Region)
- Quick Start
- EIP
- Shared Bandwidth
- Monitoring
- Product Consultation
Bandwidth
- What Are the Differences Between a Dedicated Bandwidth and a Shared Bandwidth? Can a Dedicated Bandwidth Be Changed to a Shared Bandwidth or the Other Way Around?
- Connectivity
- Change History
- API Reference (Kuala Lumpur Region)
- User Guide (Ankara Region)
- API Reference (Ankara Region)
Viewing the Cloud Service Monitoring Dashboard
A cloud service dashboard allows you to view all monitoring data of a single cloud service. If you want to collect EIP traffic statistics within a specified period or analyze the bandwidth or traffic usage of EIPs to locate faults, you can view the EIP dashboard and export EIP monitoring data.
- Choose Service List > Cloud Eye.
- In the navigation pane on the left, choose Cloud Service Monitoring.
- Viewing the EIP dashboard
- On the Cloud Service Monitoring page, click Virtual Private Cloud VPC in the Dashboard column and go to the Details page.
- Select Elastic IPs or Bandwidths as required to view detailed data.
- Viewing the global EIP dashboard
- On the Cloud Service Monitoring page, click Global EIP and Bandwidth GEIP in the Dashboard column and go to the Details page.
- Select global EIPs or internet bandwidth as required to view detailed data under the Resources and Overview tabs.
- On the Overview tab, perform the following operations:
- View information under Resource Overview, Alarm Statistics, and Key Metrics. For details, see Table 1.
Table 1 Three modules on the Overview tab Module
Resource Overview
You can view the resource data of the current cloud service in the current dimension, including Total Resources, Resources in Alarm, and Resources in Alarm in the Last 7 Days.
Alarm Statistics
You can view the total number of alarms in the last seven days, alarms of different severities (critical, major, minor, and informational), top 5 instances by total alarms, and top 5 resource groups by total alarms.
Key Metrics
You can view monitoring details of key metrics recommended by the cloud service.
- In the upper left corner of the Details page, select Resources to view corresponding monitoring details or select another cloud service to switch to its dashboard.
- On the Resources tab, perform the following operations:
- Click Export Data to export cloud service monitoring data. For details, see How Can I Export Monitoring Data?
- Locate an instance and click View Metric to view the instance metrics and HTTP status codes.
- Locate an instance and choose More > Create Alarm Rule to create an alarm rule for the instance. For details about the parameters, see Creating an Alarm Rule.
- Locate an instance and choose More > View Alarm Rule to view the alarm rules created for the instance.
