Updated on 2026-09-08 GMT+08:00
Setting the Priority for a Flink Job
In actual job running, it is necessary to prioritize and ensure the normal running of important and urgent tasks due to their varying levels of importance and urgency. This requires providing the necessary compute resources for their normal operations.
DLI offers a feature to set job priorities for each Flink job, which prioritizes the allocation of compute resources to higher priority jobs when resources are limited.
You can set the priority for Flink 1.12 or later jobs.
Notes
  • Priorities cannot be set for jobs running in queues within an elastic resource pool of the basic edition.
  • You can assign a priority level of 1 to 10 for each job, with a larger value indicating a higher priority. Compute resources are preferentially allocated to high-priority jobs. That is, if compute resources required for high-priority jobs are insufficient, compute resources for low-priority jobs are reduced.
  • Flink jobs running on a general-purpose queue have a default priority level of 5.
  • The job priority change will only be in effect once the job has been stopped, edited, and resubmitted.
  • You can set the priority for Flink jobs only after enabling dynamic scaling by setting flink.dli.job.scale.enable to true. For details, see Enabling Dynamic Scaling for Flink Jobs.
  • To change the priority for a job, you must first stop the job, change the priority level, and then submit the job for the modification to take effect.
Setting the Priority for a Flink OpenSource SQL Job
  1. Log in to the DLI management console.
  2. In the navigation pane on the left, choose Job Management > Flink Jobs.
  3. Select the job for which you want to set the priority and click Edit in the Operation column.
  4. On the far right of the displayed page, click Runtime Configuration.
  5. Enter statements in the text box to enable dynamic scaling and then set the job priority.
    To set the priority for Flink jobs, you must first enable dynamic scaling by setting flink.dli.job.scale.enable to true.
    For more parameter settings, see Enabling Dynamic Scaling for Flink Jobs.
    flink.dli.job.scale.enable=true
    flink.dli.job.priority=x
    Figure 1 Example configuration for a Flink OpenSource SQL job
Setting the Priority for a Flink Jar Job
Enter the following statement in the Runtime Configuration text box, where x indicates the priority value:
  4. In the Runtime Configuration text box, enter the following statements to enable dynamic scaling and set the job priority:
    Figure 2 Example configuration for a Flink Jar job
