Viewing Flink Job Details
After creating a Flink job, you can check the basic information, job details, task list, and execution plan of the job on the DLI console.
This section describes how to check information about a Flink job.
| Type | Description | Helpful Link |
| Basic information | Includes the job ID, job type, job execution status, and more. | |
| Job details | Includes SQL statements and the parameter settings for Flink Jar jobs. | |
| Job monitoring | You can use Cloud Eye to check job data input and output details. | |
| Task list | You can view details about each task running on a job, including the task start time, number of received and transmitted bytes, and running duration. | |
| Execution plan | You can understand the operator flow direction of a running job. |
Viewing Basic Information
In the navigation pane of the DLI console, choose Job Management > Flink Jobs. The Flink Jobs page displays all Flink jobs. You can check basic information about any Flink jobs in the list.
- Self-Managed Jobs: Flink jobs submitted via the DLI console, APIs, or SDKs. Their lifecycle—including creation, editing, starting, and stopping—is fully managed by DLI.
- Managed Jobs: Planned job list for integrating DataArts with DLI Flink.
Flink jobs submitted via the DataArts console, APIs, or SDKs. Their lifecycle is fully managed by DataArts. The DLI console provides read-only access for status viewing and does not support editing, starting, or stopping. (This feature is under planning.)
| Parameter | Description |
| ID | ID of a submitted Flink job, which is generated by the system by default. |
| Name | Name of the submitted Flink job. |
| Type | Type of the submitted Flink job, which includes:
| Status | Job status, which is subject to the console. |
| Description | Description of the submitted Flink job. |
| Username | Name of the user who submits the job. |
| Created | Time when the job was created. |
| Started | Time when the Flink job started to run. |
| Duration | Time consumed by job running. |
| Operation |
Viewing Details
This section describes how to view job details. After you create and save a job, you can click the job name to view job details, including SQL statements and parameter settings. For a Jar job, you can only view its parameter settings.
- In the left navigation pane of the DLI management console, choose > . The Flink Jobs page is displayed.
- Click the name of your desired job.
On the displayed page, you can view the job details, SQL statements, job configuration information, task list, execution plan, commit logs, run logs, log list, and job tags.
Viewing Monitoring Information
You can use Cloud Eye to view details about job data input and output.
- Click the name of the job you want. The job details are displayed. Click Job Monitoring in the upper right corner of the page to switch to the Cloud Eye console.Figure 1 Monitoring a Job
The following table describes monitoring metrics related to Flink jobs.
Table 3 Monitoring metrics related to Flink jobs Name
Flink Job Data Read Rate
Displays the data input rate of a Flink job for monitoring and debugging. Unit: record/s.
Flink Job Data Write Rate
Displays the data output rate of a Flink job for monitoring and debugging. Unit: record/s.
Flink Job Total Data Read
Displays the total number of data inputs of a Flink job for monitoring and debugging. Unit: records
Flink Job Total Data Write
Displays the total number of output data records of a Flink job for monitoring and debugging. Unit: records
Flink Job Byte Read Rate
Displays the number of input bytes per second of a Flink job. Unit: byte/s
Flink Job Byte Write Rate
Displays the number of output bytes per second of a Flink job. Unit: byte/s
Flink Job Total Read Byte
Displays the total number of input bytes of a Flink job. Unit: byte
Flink Job Total Write Byte
Displays the total number of output bytes of a Flink job. Unit: byte
Flink Job CPU Usage
Displays the CPU usage of Flink jobs. Unit: %
Flink Job Memory Usage
Displays the memory usage of Flink jobs. Unit: %
Flink Job Max Operator Latency
Displays the maximum operator delay of a Flink job. The unit is ms.
Flink Job Maximum Operator Backpressure
Displays the maximum operator backpressure value of a Flink job. A larger value indicates severer backpressure.
0: OK
50: low
100: high
Viewing the Task List
If the value is 0, no data is received from the data source.
- On Task List and view the node information about the task. Figure 2 Task list
View the operator task list. The following table describes the task parameters.Table 4 Parameter descriptions Parameter
Name
Name of an operator.
Duration
Running duration of an operator.
Max Concurrent Jobs
Number of parallel tasks in an operator.
Task
Operator tasks are categorized as follows:
- The digit in red indicates the number of failed tasks.
- The digit in light gray indicates the number of canceled tasks.
- The digit in yellow indicates the number of tasks that are being canceled.
- The digit in green indicates the number of finished tasks.
- The digit in blue indicates the number of running tasks.
- The digit in sky blue indicates the number of tasks that are being deployed.
- The digit in dark gray indicates the number of tasks in a queue.
Status
Status of an operator task.
Back Pressure Status
Working load status of an operator. Available options are as follows:
- OK: indicates that the operator is in normal working load.
- LOW: indicates that the operator is in slightly high working load. DLI processes data quickly.
- HIGH: indicates that the operator is in high working load. The data input speed at the source end is slow.
Delay
Duration from the time when source data starts being processed to the time when data reaches the current operator. The unit is millisecond.
Sent Records
Number of data records sent by an operator.
Sent Bytes
Number of bytes sent by an operator.
Received Bytes
Number of bytes received by an operator.
Received Records
Number of data records received by an operator.
Started
Time when an operator starts running.
Ended
Time when an operator stops running.
Viewing the Execution Plan
You can view the execution plan to understand the operator stream information about the running job.
- Click the Execution Plan tab to view the operator flow direction. Figure 3 Execution plan
Click a node. The corresponding information is displayed on the right of the page.- Scroll the mouse wheel to zoom in or out.
- The stream diagram displays the operator stream information about the running job in real time.
