Updated on 2026-09-08 GMT+08:00
Checking Basic Information
After creating an elastic resource pool, you can check and manage it on the management console.
This section describes how to check basic information about an elastic resource pool on the management console, including the VPC CIDR block, IPv6 CIDR block, and creation time.
  1. Log in to the DLI management console.
  2. In the navigation pane, choose Resources > Resource Pool.
  3. On the displayed page, select the elastic resource pool you want to check.
    • In the upper right corner of the list page, click to customize the columns to display and set the rules for displaying the table content and the Operation column.
    • In the search box above the list, you can filter the required elastic resource pool by name or tag.
  4. Click to expand the basic information card of the elastic resource pool and view detailed information about the pool.
    These details include the name of the pool, the user who created it, the date it was created, whether IPv6 is enabled, and the VPC CIDR block. If IPv6 is enabled, the subnet's IPv6 CIDR block will also be displayed.
    For details about the definitions of actual CUs, used CUs, CU range, and yearly/monthly CUs (specifications) of the elastic resource pool, see Basic Concepts of Elastic Resource Pools.
    Figure 1 Basic information about an elastic resource pool
This section explains the meanings of actual CUs, used CUs, CU range, and yearly/monthly CUs (specifications) in elastic resource pools.
