Updated on 2026-09-08 GMT+08:00
Managing Permissions
Administrators can assign permissions of different operation scopes to users for each elastic resource pool.
Precautions
  • The administrator and elastic resource pool owner have all permissions, which cannot be set or modified by other users.
  • When you set resource pool permissions for a new user, ensure that the region of the user group to which the user belongs has the Tenant Guest permission. For details about the Tenant Guest permission and how to apply for the permission, see Creating a User Group and Assigning Permissions and System Permissions.
  1. In the navigation pane on the left of the DLI console, choose Resources > Resource Pool.
  2. Select the desired elastic resource pool and choose More > Permissions in the Operation column. The User Permissions area displays the list of users who have permissions of elastic resource pools.
    You can assign permissions to new users, modify permissions for users who already have some permissions of elastic resource pools, and revoke all permissions of a user on a pool.
    • Assign permissions to a new user.
      A new user does not have permissions on the elastic resource pool.
      1. Click Set Permission in the Operations column on User Permissions page. The Set Permission dialog box is displayed.
      2. Set Username to the name of the desired IAM user, and select the required permissions for the user.
      3. Click OK to.
        Table 1 describes the related parameters.
        Figure 1 Managing permissions
        Table 1 Parameter descriptions
        Username
        Name of the user you want to grant permissions to
        The username must be an existing IAM username and has been used to log in to the DLI management console.
        Select the permissions to be granted to the user
        • Update: Update the description of an elastic resource pool.
        • Resources: Add queues, delete queues, and configure scaling policies for queues in an elastic resource pool.
        • Delete: Delete the elastic resource pool.
        • Modify Specifications: Change the specifications of a yearly/monthly elastic resource pool.
        • Grant Permission: Grant the elastic resource pool permissions to other users.
        • Revoke Permission: Revoke the permissions that other users have but you cannot revoke the owner's permissions.
        • View Other User's Permissions: View the elastic resource pool permissions of other users.
    • To grant or revoke permissions for a user who already has certain permissions on a queue, perform the following steps:
      1. In the list under User Permissions, select the user whose permissions need to be modified and click Set Permission in the Operation column.
      2. In the displayed Set Permission dialog box, modify the permissions of the user. Table 1 lists the detailed permission descriptions.
        If Set Permission is gray, you are not allowed to change permissions on this elastic resource pool. You can apply to the administrator, elastic resource pool owner, or other authorized users for granting and revoking permissions.
        Figure 2 Managing permissions
      3. Click OK.
    • To revoke all permissions from a user, perform the following steps:
      In the list under User Permissions, select the desired user whose permissions and click Set Permission in the Operation column. Click Yes in the Revoke Permission dialog box.
