Viewing Scaling History
If you added a queue to or deleted one from an elastic resource pool, or you scaled an added queue, the CU quantity of the elastic resource pool may be changed. You can view historical CU changes of an elastic resource pool on the console.
Notes and Constraints
Currently, you can only view the historical records generated within the last 30 days on the console.
Viewing Scaling History of an Elastic Resource Pool
- In the navigation pane on the left, choose Resources > Resource Pool.
- Select the desired elastic resource pool and choose More > Expansion History in the Operation column.
- On the displayed page, select a duration to view the CU usage.
You can view the number of CUs before and after a scaling, and the target number of CUs.
The historical records can be displayed in charts or tables. Click
in the upper right corner to switch the display.
For example, the scaling is abnormal according to Viewing Scaling History, and the Figure 2 shows that the target number of CUs is 80, the original number of CUs is 64, and the scaled number of CUs is 64. The scaling fails.
Figure 1 Scaling history in a chart
