Help Center/ Data Lake Insight/ User Guide/ Configuring DLI to Read and Write Data from and to External Data Sources/ Example Typical Scenario: Configuring Network Connectivity Between DLI and Data Sources on the Internet
Updated on 2026-09-08 GMT+08:00
A public network data source is one that is accessible over the Internet and has a public IP address. By connecting DLI to the public network, you can access these data sources.
This section explains how to connect DLI to a public network by setting up SNAT rules and configuring routing information.
Figure 1 Configuration process
Step 1: Create a VPC
Log in to the VPC console and create a VPC. The created VPC is used for NAT to access the public network.
For details about how to create a VPC, see Creating a VPC.
Figure 2 Creating a VPC
Step 2: Create an Elastic Resource Pool and Create Queues Within It
  1. Log in to the DLI management console.
  2. In the navigation pane on the left, choose Resources > Resource Pool.
  3. On the displayed page, click Buy Resource Pool in the upper right corner.
  4. On the displayed page, set the parameters.
    Table 1 Parameter descriptions
    Region
    Select a region where you want to buy the elastic resource pool.
    Project
    Project uniquely preset by the system for each region
    Name
    Name of the elastic resource pool
    Specifications
    Specifications of the elastic resource pool
    CU Range
    The maximum and minimum CUs allowed for the elastic resource pool
    CIDR Block
    CIDR block the elastic resource pool belongs to. If you use an enhanced datasource connection, this CIDR block cannot overlap that of the data source. Once set, this CIDR block cannot be changed.
    Enterprise Project
    Select an enterprise project for the elastic resource pool.
  5. Click Buy.
  6. Click Submit.
  7. In the elastic resource pool list, locate the pool you just created and click Add Queue in the Operation column.
  8. Set the basic parameters listed below.
    Table 2 Basic parameters for adding a queue
    Name
    Name of the queue to add
    Type
    Type of the queue
    • To execute SQL jobs, select For SQL.
    • To execute Flink or Spark jobs, select For general purpose.
    Engine
    You can only select Spark if setting Type to For SQL.
    Enterprise Project
  9. Click Next and configure scaling policies for the queue.
    Click Create to add a scaling policy with varying priority, period, minimum CUs, and maximum CUs.
    Figure 3 shows the scaling policy configured in this example.
    Figure 3 Configuring a scaling policy when adding a queue
    Table 3 Scaling policy parameters
    Example Value
    Priority
    Priority of the scaling policy in the current elastic resource pool. A larger value indicates a higher priority. In this example, only one scaling policy is configured, so its priority is set to 1 by default.
    Period
    The first scaling policy is the default policy, and its Period parameter configuration cannot be deleted or modified.
    The period for the scaling policy is from 00 to 24.
    00-24
    Min CU
    Minimum number of CUs allowed by the scaling policy
    16
    Max CU
    Maximum number of CUs allowed by the scaling policy
    64
  10. Click OK.
Step 3: Create an Enhanced Datasource Connection Between the Queue and a VPC
  1. In the navigation pane of the DLI management console, choose Datasource Connections.
  2. In the Enhanced tab, click Create.
    Enter the connection name, select the created queue, VPC, and subnet, and enter the host information (optional).
    Figure 4 Creating an enhanced datasource connection
Step 4: Buy an EIP
  1. Log in to the EIPs page of the network console, click Buy EIP.
  2. In the displayed page, configure the parameters as required.
    For details about how to set the parameters, see Buy EIP.
Step 5: Configure a NAT Gateway
  1. Create a NAT gateway.
    1. Log in to the console and search for NAT Gateway in the Service List. The Public NAT Gateways page of the network console is displayed.
    2. Click Buy Public NAT Gateway and configure the required parameters.
      For details, see Buying a Public NAT Gateway.
      Figure 5 Buying a NAT gateway
    3. Click Next, confirm the configurations, and click Submit.
      During the configuration, set VPC to the one created in Step 1: Create a VPC.
  2. Add a route.
    In the navigation pane on the left of the network console, choose Virtual Private Cloud > Route Tables. After a NAT gateway instance is created, a route to that gateway is automatically created. Click the route table name to view the automatically created route.
    The destination address is the public IP address you want to access, and the next hop is the NAT gateway.
    Figure 6 Viewing the route
  3. Add an SNAT rule.
    You need to add SNAT rules for the new NAT gateway to allow the hosts in the subnet to communicate with the Internet.
    1. Click the name of the created NAT gateway on the Public NAT Gateways page of the network console.
    2. On the SNAT Rules tab, click Add SNAT Rule.
      For details, see Adding an SNAT Rule.
    3. Scenario: Select Direct Connect/Cloud Connect.
    4. Subnet: Select the subnet where the queue you want to connect locates.
    5. EIP: Select the target EIP.
      Figure 7 Adding an SNAT rule
    6. Click OK.
Step 6: Add a Custom Route
Add a custom route for the enhanced datasource connection you have created. Specify the route information of the IP address you want to access.
For details, see Custom Route Information.
Figure 8 Adding route information
Step 7: Test the Connectivity to the Public Network
Test the connectivity between the queue and the public network. Click More > Test Address Connectivity in the Operation column of the target queue and enter the public IP address you want to access.
Figure 9 Testing address connectivity
