Help Center/ Data Lake Insight/ User Guide/ Creating an Elastic Resource Pool and Creating Queues Within It/ Managing Queues/ Deleting a Queue
Updated on 2026-05-26 GMT+08:00
Deleting a Queue
You can delete a queue based on actual conditions.
- This operation will fail if there are jobs in the Submitting or Running state on this queue.
- Deleting a queue does not cause table data loss in your database.
- Log in to the DLI management console.
- In the navigation pane, choose Resources > Queue Management.
- Locate the row containing the queue to delete and click Delete in its Operation column. Figure 1 Deleting a Queue
If Delete in the Operation column is gray, the current user does not have the permission of deleting the queue. You can apply to the administrator for the permission.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
