Help Center/ Data Lake Insight/ User Guide/ Creating an Elastic Resource Pool and Creating Queues Within It/ Managing Queues/ Enabling Elastic Scaling for a Queue in a Non-Elastic Resource Pool
Updated on 2026-09-08 GMT+08:00
Newly created pay-per-use queues need to run jobs before they can be scaled in or out.
The operations described in this section only apply to queues in non-elastic resource pools.
Notes and Constraints
  • Queues with 16 CUs do not support scale-out or scale-in.
  • Queues with 64 CUs do not support scale-in.
  • Only queues whose billing mode is Pay-per-use/By CUH and Pay-per-use/Dedicated resource mode support elastic scaling.
  • If Status of queue xxx is assigning, which is not available is displayed on the Elastic Scaling page, the queue can be scaled only after the queue resources are allocated.
  • If there are not enough physical resources, a queue may not be able to scale out to the desired target size.
  • The system does not guarantee that a queue will be scaled in to the desired target size. Typically, the system checks the resource usage before scaling in the queue to determine if there is enough space for scaling in. If the existing resources cannot be scaled in according to the minimum scaling step, the queue may not be scaled in successfully or only partially.
    The scaling step may vary depending on the resource specifications, usually 16 CUs, 32 CUs, 48 CUs, 64 CUs, and more.
    For example, if the queue size is 48 CUs and job execution uses 18 CUs, the remaining 30 CUs do not meet the requirement for scaling in by the minimum step of 32 CUs. If a scaling in task is executed, it will fail.
Scaling Out
If the current queue specifications do not meet service requirements, you can add the number of CUs to scale out the queue.
Scale-out is time-consuming. After you perform scale-out on the Elastic Scaling page of DLI, wait for about 10 minutes. The duration is related to the CU amount to add. After a period of time, refresh the Queue Management page and check whether values of Specifications and Actual CUs are the same to determine whether the scale-out is successful. Alternatively, on the Job Management page, check the status of the SCALE_QUEUE SQL job. If the job status is Scaling, the queue is being scaled out.
The procedure is as follows:
  1. In the navigation pane on the left of the DLI management console, choose Resources > Queue Management.
  2. Select the queue to be scaled out, click More in the Operation column, and select Elastic Scaling.
  3. On the displayed page, select Scale-out for Operation and set the scale-out amount.
    Figure 1 Scale-out
  4. Click OK.
Scaling In
If the current queue specifications are too much for your computing service, you can reduce the number of CUs to scale in the queue.
  • Scale-in is time-consuming. After you perform scale-in on the Elastic Scaling page of DLI, wait for about 10 minutes. The duration is related to the CU amount to reduce. After a period of time, refresh the Queue Management page and check whether values of Specifications and Actual CUs are the same to determine whether the scale-in is successful. Alternatively, on the Job Management page, check the status of the SCALE_QUEUE SQL job. If the job status is Scaling, the queue is being scaled in.
  • By default, the minimum number of CUs is 16. That is, when the queue specifications are 16 CUs, you cannot scale in the queue.
  2. Select the queue to be scaled in, click More in the Operation column, and select Elastic Scaling.
  3. On the displayed page, select Scale-in for Operation and set the scale-in amount.
    Figure 2 Manual scale-in
  4. Click OK.
