Updated on 2025-08-08 GMT+08:00
Overview
You can create contingency plans for potential system failures in Resilience Center of COC. These contingency plans can help you to restore services after a fault occurs. You can log in to COC, choose Resilience Center > Contingency Plans. On the displayed page, you can create a contingency plan as needed by configuring basic information, selecting a handling method (such as scripts or jobs), and associating the contingency plan with the corresponding scripts or jobs. Also, you can check, modify, or delete created contingency plans.
