Managing Change Review Tickets
To create a change ticket, you need to configure the review process and reviewer from the change type and change level dimensions based on service requirements.
Creating a Review Configuration
- Log in to COC.
- In the navigation pane on the left, choose Change Ticket Management > Change Center.
- Click Create Review Configurations in the upper right corner.
- Set parameters for creating a review configuration.
Table 1 Parameters for creating a review configuration task Parameter
Change Type
The options are Regular and Urgent.
Only one change type can be configured each time.
Level
The options are A, B, C, and D (A > B > C > D).
You can select multiple change levels at the same time.
Select a value from the drop-down list box based on the configured shift scenario and role. For details about how to configure a shift, see Shift Schedule Management.
A shift role becomes active only after a reviewer is assigned. Without a reviewer, the change request cannot be submitted.
Review Rule: The options are One-member Approval and All-member Approval.
You can add up to five levels of reviews.
- Click OK.
The review configuration task is created.
Modifying a Review Configuration
Only the creator and management account can modify review configurations.
- Log in to COC.
- Locate the action you want to review and click Modify in the Operation column.
- Set parameters for modifying a review configuration.
Table 2 Parameters for modifying review configurations Parameter
Change Type
Level
- Click OK.
The review configurations are modified.
Deleting a Review Configuration
Only the creator and management account of a review configuration can delete it.
- Log in to COC.
- Locate the action you want to review and click Delete in the Operation column.
- Click OK.
The review configuration is deleted.
