ECS Diagnosis
Backed by Huawei Cloud's accumulated expertise and detection algorithms, ECS diagnostic tool collects a small amount of guest OS data to help you quickly learn server statuses and provides troubleshooting methods.
Precautions
The UniAgent status of the target instance must be Running. For details about UniAgent operations, see Configuring a UniAgent.
The ECS diagnosis plug-in can only be used for some OSs. For details, see the following table.
VM Architecture |
OS Type |
Supported by holmes-agent (Y/N) |
x86 |
Huawei Cloud EulerOS |
Huawei Cloud EulerOS 2.0 Standard Edition 64-bit (40 GB) |
Y |
CentOS |
CentOS 7.9 |
Y |
CentOS 8.0 |
Y |
CentOS 8.2 64-bit |
Y |
CentOS 7.8 |
Y |
CentOS 7.7 |
Y |
CentOS 7.6 |
Y |
CentOS 7.5 |
Y |
CentOS 7.4 |
Y |
CentOS 7.3 |
Y |
CentOS 7.2 |
Y |
CentOS 6.10 |
N |
Ubuntu |
Ubuntu 20.04 server 64-bit |
Y |
Ubuntu 22.04 server 64-bit |
Y |
Ubuntu 18.04 server 64-bit |
Y |
Ubuntu 16.04 server 64-bit |
Y |
EulerOS |
EulerOS 2.5 64-bit |
Y |
Debian |
Debian 9.0.0 64-bit |
Y |
Debian 8.8.0 64-bit |
Y |
Debian 8.2.0 64-bit |
Y |
Debian 12.0.0 64-bit |
N |
Debian 11.1.0 64-bit |
Y |
Debian 10.0.0 64-bit |
Y |
OpenSUSE |
openSUSE 15.0 64-bit |
Y |
AlmaLinux |
AlmaLinux 9.0 64-bit |
N |
AlmaLinux 8.4 64-bit |
N |
AlmaLinux 8.3 64-bit |
N |
Rocky Linux |
Rocky Linux 9.0 64-bit |
N |
Rocky Linux 8.5 64-bit |
N |
Rocky Linux 8.4 64-bit |
N |
CentOS Stream |
CentOS Stream 9 64-bit |
Y |
CentOS Stream 8 64-bit |
Y |
CoreOS |
CoreOS 2079.4.0 64-bit |
N |
openEuler |
openEuler 22.03 64-bit |
Y |
openEuler 20.03 64-bit |
Y |
Others |
FreeBSD 11.0-RELEASE 64-bit |
N |
Arm |
Y |
Ubuntu |
Y |
CentOS |
CentOS 7.6 64-bit with Arm |
N |
EulerOS |
EulerOS: 2.8 64-bit with Arm |
N |
Debian |
Debian 10.2.0 64-bit with Arm |
N |
Kylin OS |
Kylin Linux Advanced Server for Kunpeng V10 |
N |
openEuler |
openEuler 20.03 64-bit with Arm |
N |
Windows |
Windows2012 |
Windows Server 2012 R2 Datacenter 64-bit English |
N |
Windows Server 2012 R2 Standard 64-bit English |
N |
Windows Server 2012 R2 Datacenter 64-bit Chinese |
N |
Windows Server 2012 R2 Standard 64-bit Chinese |
N |
Windows2016 |
Windows Server 2016 Datacenter 64-bit English (40 GB) |
Y |
Windows Server 2016 Standard 64-bit English (40 GB) |
Y |
Windows Server 2016 Datacenter 64-bit Chinese (40 GB) |
Y |
Windows Server 2016 Standard 64-bit Chinese (40 GB) |
Y |
Windows2019 |
Windows Server 2019 Datacenter 64-bit English (40 GB) |
Y |
Windows Server 2019 Standard 64-bit English (40 GB) |
Y |
Windows Server 2019 Datacenter 64-bit Chinese (40 GB) |
Y |
Windows Server 2019 Standard 64-bit Chinese (40 GB) |
Y |
Windows2022 |
Windows Server 2022 Datacenter 64-bit Chinese (40 GB) |
Y |
Windows Server 2022 Standard 64-bit Chinese (40 GB) |
Y |
Windows Server 2022 Datacenter 64-bit English (40 GB) |
Y |
Windows Server 2022 Standard 64-bit English (40 GB) |
Y |
ECS Diagnosis
- Log in to COC.
- In the navigation pane, choose Fault Management > Trouble Diagnosis.
- Click Diagnose Now on the Diagnose ECS card.
- Click Add and configure the parameters on the Select Instance dialog box.
Table 2 Parameters for selecting an instance Parameter
Example Value
Selection Method
Select an instance selection method.
- Manual Selection: Manually select an instance based on Enterprise Project, View Type, Resource Type, Region, and Target Instance.
- Auto select all: This option is not supported currently.
Manual Selection
Enterprise Project
Select an enterprise project from the drop-down list. You can choose All.
All
View Type
Select a view type.
- CloudCMDB resources: Select an instance from the resource list.
- CloudCMDB application groups: Select an instance from the application group list.
CloudCMDB resources
Resource Type
The default value is used and cannot be changed.
ECS
Region
Select a region from the drop-down list.
CN-Hong Kong
Target Instance
Set filter criteria in the filter box and select the filtered instances.
- Select I agree to install the plug-in and collect data based on the Guest OS Diagnosis Service Frontend Data Collection License. and click OK.
- Click OK.
After the diagnosis is complete, view the diagnosis report.
