Managing Alarm Conversion Rules
After an alarm conversion rule is created, if you want to disable, enable, modify, copy, or delete the rule, perform the operations in this section.
Disabling an Alarm Conversion Rule
- Log in to COC.
- In the navigation tree on the left, choose Fault Management > Alarm Conversion Rules.
- Select the rule to be disabled and click Disable in the Operation column.
- Click OK.
The alarm conversion rule is disabled.
Enabling an Alarm Conversion Rule
- Log in to COC.
- Select the rule you want to enable and click Enable in the Operation column.
- Click OK.
The alarm conversion rule is enabled.
Modifying an Alarm Conversion Rule
- Log in to COC.
- Locate the action you want to modify and click More in the Operation column and choose Modify.
- The parameters for creating an alarm conversion rule are similar to those for creating an alarm conversion rule. For details, see Creating an Alarm Conversion Rule.
- Click OK.
The alarm conversion rule is modified.
Copying an Alarm Conversion Rule
- Log in to COC.
- Select the rule to be disabled and click Copy in the Operation column.
- Click OK.
The alarm conversion rule is copied.
Deleting an Alarm Conversion Rule
- Log in to COC.
- Locate the action you want to review and click More in the Operation column and choose Delete.
- Click OK.
The alarm conversion rule is deleted.
