Viewing Raw Alarms
Raw alarms are generated based on the alarm information collected from multiple existing or third-party monitoring systems (such as Cloud Eye, AOM, and Prometheus). The original alarm list displays the alarm source name, alarm status, alarm severity, alarm source, and associated application.
You can create an alarm conversion rule to aggregate one or more raw alarms into a single aggregated alarm. One original alarm can trigger multiple alarm conversion rules.
Precautions
By default, the page displays alarm information of the last 31 days. Expired alarms are automatically cleared.
Viewing Raw Alarms
- Log in to COC.
 - In the navigation pane, choose Fault Management > Alarms.
 - On the Original Alarm tab, click an alarm name.
View the original alarm details.
