Updated on 2025-08-08 GMT+08:00
Viewing Capacity Details
Cloud Operations Center allows you to view the capacity details of resources associated with applications, sub-applications, components, or groups, and displays core resource data and rankings by resource type.
- Log in to COC.
- In the navigation pane, choose Resources > Application and Resource Management.
- Click Applications in the upper left corner.
- In the application list on the left, select the application, sub-application, component, or group to be viewed. Click Capacity on the right of the page.
Figure 1 Viewing capacity rankings
