Help Center/
Cloud Operations Center/
User Guide/
Application Management/
Disassociating Resources from an Application Group
Updated on 2025-09-23 GMT+08:00
After a group is associated with resources, if you need to disassociate the resources from the group, perform the operations in this section.
- Log in to COC.
- In the navigation pane, choose Resources > Application and Resource Management.
- Click Applications in the upper left corner.
- In the application list on the left, expand the application, select a group, select the resources to be disassociated, and click Disassociate.
Figure 1 Disassociating a resource from a group
- Click OK.
The resource disassociation is complete.
