Using AppArmor to Confine Container Access to Resources
Application Armor (AppArmor) is a security module of the Linux kernel, which is usually used in OSs such as Ubuntu. AppArmor allows system administrators to associate each program with a security profile to confine program functions. AppArmor is an access control system similar to SELinux. It can be used to specify which files a program can read, write, or run, and whether the program can access network ports. AppArmor supplements the traditional Unix discretionary access control (DAC) model by providing mandatory access control (MAC). It has been integrated into the Linux kernel since version 2.6.
This section describes how to use AppArmor to confine container access to resources on Ubuntu nodes in a CCE cluster.
Notes and Constraints
- This feature is supported only in clusters of v1.31.6-r0 or later, and the nodes must run Ubuntu. Ensure that your cluster version and node OS meet the requirements.
- The version of the Everest add-on in the cluster must be 2.4.158 or later.
- After AppArmor is enabled on a node, Docker or containerd applies the default AppArmor profile to pods scheduled to the node even if the appArmorProfile parameters are not configured for the pods. The AppArmor profile is not enforced when the appArmorProfile.type parameter is explicitly set to Unconfined for the pods. For details, see Using AppArmor Profiles to Secure Pods.
- Operations that trigger node reset, such as resetting a node or synchronizing a node pool, will disable AppArmor. If you need to disable AppArmor on a node, reset the node. Currently, AppArmor cannot be manually disabled.
Enabling AppArmor on a Node
- Log in to the Ubuntu node and install AppArmor.
sudo DEBIAN_FRONTEND=noninteractive apt-get -y install apparmor
If a private Ubuntu image is used, pre-install AppArmor in the image.
- Check the AppArmor status.
sudo aa-status
If the following information is displayed, AppArmor has been loaded:
apparmor module is loaded.
- Start AppArmor and set it to be automatically started upon system boot. When the node is restarted, the AppArmor profile is automatically reloaded.
sudo systemctl enable apparmor sudo systemctl start apparmor
- Check whether the system is started. If Y is returned, the system is started.
sudo cat /sys/module/apparmor/parameters/enabled
The parameters in the command output are read by kubelet to check whether AppArmor is enabled on the node. If AppArmor is not enabled on the node, pods with AppArmor settings will be intercepted when they are scheduled to this node.
Restart kubelet to read the parameters in the command output. (AppArmor is enabled by default in kubelet 1.31 GA.)sudo systemctl restart kubelet
Enabling AppArmor on a Container Runtime
containerd
- Modify the containerd configuration.
vim /etc/containerd/config.toml
- Modify the following content and save the modification:
[plugins."io.containerd.grpc.v1.cri"] disable_apparmor = false
- Restart containerd.
sudo systemctl restart containerd
Docker
- Modify the Docker configuration.
vim /etc/default/docker
- Use # to comment out container='disable apparmor'.
# container='disable apparmor'
- Restart Docker.
sudo systemctl restart docker
AppArmor profiles can be specified at the pod or container level. If a pod-level profile is set, it will be used as the default profile for all containers (including init, sidecar, and ephemeral containers) in the pod. If both pod- and container-level profiles are set, the container-level profile is preferentially used. The following shows an example configuration:
securityContext:
appArmorProfile:
type: <profile_type>
... The options of <profile_type> are as follows:
- Localhost: The profile loaded on the node is used. For details, see Example: Using Custom AppArmor Profile to Confine a Pod.
- RuntimeDefault: The default profile is used.
- Unconfined: The AppArmor profile is not enforced.
For details about the AppArmor profile API, see Specifying AppArmor Confinement.
When privileged containers are enabled for a pod (privileged: true), configure rules for the AppArmor configuration to take effect. For details, see Rules for AppArmor Configurations to Take Effect After AppArmor Is Enabled for Privileged Containers.
To verify that a container's root process is running with the correct profile, you can check its process attributes.
kubectl exec <pod_name> -- cat /proc/1/attr/current An example output is as follows:
cri-containerd.apparmor.d (enforce)
- Load the custom AppArmor profile onto the node. You can define the profile name.
vim /etc/apparmor.d/k8s-apparmor-example-deny-writeThe following is an example. The profile denies all file write operations. For details about the profile writing syntax, see the AppArmor Profile Quick Guide.
#include <tunables/global> profile k8s-apparmor-example-deny-write flags=(attach_disconnected) { #include <abstractions/base> file, # Deny all file writes. deny /** w, }Load the profile.
apparmor_parser -r /etc/apparmor.d/k8s-apparmor-example-deny-write
The AppArmor profile needs to be loaded onto each node that needs to use AppArmor.
- Create a simple pod as follows and add the AppArmor rules for the pod to reject file writing as set in the previous step. Create the hello-apparmor.yaml file and add the following content to the file:
apiVersion: v1 kind: Pod metadata: name: hello-apparmor spec: securityContext: appArmorProfile: type: Localhost # Use the AppArmor profile loaded on the node. localhostProfile: k8s-apparmor-example-deny-write # Define the name of the AppArmor profile loaded on the node. containers: - name: hello image: busybox:1.28 command: [ "sh", "-c", "echo 'Hello AppArmor!' && sleep 1h" ]
If the cluster contains nodes that do not support AppArmor, use affinity scheduling to schedule the pod to a node that supports AppArmor. For details, see Configuring Node Affinity Scheduling (nodeAffinity).
- Create a sample pod.
kubectl create -f hello-apparmor.yaml
- When the pod is running, check the /proc/1/attr/current file of the container to verify that the container is running with the AppArmor profile.
kubectl exec hello-apparmor -- cat /proc/1/attr/current
If the following information is displayed, the AppArmor profile has been applied to the container:
k8s-apparmor-example-deny-write (enforce)
- Write files to violate the AppArmor profile and check whether the profile takes effect.
kubectl exec hello-apparmor -- touch /tmp/test
If the following information is displayed, the write operation is rejected, and the profile takes effect:
touch: /tmp/test: Permission denied command terminated with exit code 1
If privileged containers are enabled for a pod (privileged: true), the rules for AppArmor configurations to take effect are as follows.
| Pod AppArmor Configuration | Privileged Containers Not Used | Privileged Containers Used (privileged: true) |
| AppArmor not enabled | Use the default policy of the container runtime. | The AppArmor profile is not enforced. |
| RuntimeDefault | Use the default policy of the container runtime. | The AppArmor profile is not enforced. |
| Unconfined | The AppArmor profile is not enforced. | The AppArmor profile is not enforced. |
| Localhost | Use the AppArmor profile loaded on the node. | Use the AppArmor profile loaded on the node. |
