Updated on 2026-09-21 GMT+08:00
NPU Metrics
If the CCE AI Suite (Ascend NPU) add-on version is 2.1.55 or later, NPU-Exporter can be used to monitor and collect Ascend AI processor metrics. NPU-Exporter is designed to obtain and report runtime data of Ascend AI chips, including the number of Ascend AI processors and real-time network port receiving rate. These metrics are referred to as NPU metrics. By monitoring NPU metrics, you can gain real-time visibility into NPU performance, detect and resolve potential issues, and ensure that NPUs run stably and efficiently. This section provides a detailed overview of the NPU metrics reported by NPU-Exporter.
Billing
NPU metrics are custom metrics. Uploading such metrics to AOM incurs fees. For details, see Pricing Details.
Applicable NPU Nodes
Only NPU metrics of the nodes listed in AI-accelerated ECSs can be monitored and collected.
NPU Metrics
NPU-Exporter can collect 73 NPU metrics. This section focuses on the common metrics supported by nodes listed in AI-accelerated ECSs. For details, see Table 1.
Table 1 NPU metrics
Category
Metric
Metric Label
Field Type
NPU
npu_chip_info_name
Name and ID of an Ascend AI processor
container_name: a container name
String
id: an NPU ID
String
model_name: name of an Ascend AI processor
String
namespace: a namespace name
String
pcie_bus_info: PCIe information of an Ascend AI processor
String
pod_name: a pod name
String
vdie_id: Unique ID of an Ascend AI processor, which can be used as the UUID of the NPU
String
npu_chip_info_health_status
Health status of an Ascend AI processor.
  • 0: The Ascend AI processor is unhealthy.
  • 1: The Ascend AI processor is healthy.
String
id: an NPU ID
String
String
String
String
String
String
npu_chip_info_power
Power consumption of an Ascend AI processor, in watts (W)
If the NPU on the node is Snt3P, this metric specifies the board power consumption. If the NPU is Snt3, this metric specifies the power consumption of the Ascend AI processor.
String
id: an NPU ID
String
String
String
String
String
String
npu_chip_info_temperature
Temperature of an Ascend AI processor, in degrees Celsius (°C)
String
id: an NPU ID
String
String
String
String
String
String
npu_chip_info_utilization
AI Core usage of an Ascend AI processor, in percentage
String
id: an NPU ID
String
String
String
String
String
String
npu_chip_info_vector_utilization
AI Vector usage of an Ascend AI processor
String
id: an NPU ID
String
String
String
String
String
String
DDR
npu_chip_info_used_memory
Used DDR memory of an Ascend AI processor, in MB
String
id: an NPU ID
String
String
String
String
String
String
npu_chip_info_total_memory
Total DDR memory of an Ascend AI processor, in MB
String
id: an NPU ID
String
String
String
String
String
String
Helpful Links
You can use NPU-Exporter to monitor these NPU metrics. For details, see Comprehensive Monitoring of NPU Metrics.
