Modifying the Auto-Renewal Configuration of a Yearly/Monthly Node Pool
Node pools billed on a yearly/monthly basis support auto-renewal. To change the auto-renewal period, follow the instructions provided in this section.
Notes and Constraints
After the auto-renewal configuration of a yearly/monthly node pool is modified, the modification takes effect only on new nodes. To apply the modification onto existing nodes, manually modify the auto-renewal configuration. For details, see Modifying the Auto-Renewal Configuration of a Yearly/Monthly Node.
Modifying Auto-Renewal
- In the navigation pane, choose Nodes. Click Update in the Operation column of the target node pool.
- On the Update Node Pool page, enable or disable auto-renewal as needed.
- If the original node pool is purchased by month, the subsequent renewal period is one month after auto-renewal is enabled.
- If the original node pool is purchased by year, the subsequent renewal period is one year after auto-renewal is enabled.
- Click Next: Confirm, confirm the modification, and click Submit.
