Changing a Backup Name
During routine operations, a large number of policy-driven backups accumulate in the vault as backup tasks continue to run. These backups often have system-generated names (for example, autobk_20251230_123456), which may not be intuitive and can make it difficult to quickly identify the related service, server, or key point in time. When you need to restore a specific application (such as an ERP system or a database) or restore a resource to a previous state, clear and meaningful backup names greatly improve search efficiency and operation accuracy.
By changing a backup name, you can add a custom identifier (for example, RHEL8_OAsystem_BackupBeforeUpgrade_20251230) to either a manual or automated backup, making subsequent management and restoration much easier.
This section describes how to change a backup name.
There is at least one backup.
- Duplicate backup names are allowed.
- If the name of a backup is changed and the prefix is deleted, you may find it difficult to know whether it is an automatic backup or a manual backup.
- Log in to the CBR console. Click
in the upper left corner and select a region. - Click the Backups tab and set filter criteria to view the backups.
- Click the name of the target backup to go to the backup details page.
- Click
next to the backup name. A backup name can be up to 64 characters. Only letters, digits, underscores (_), and hyphens (-) are allowed. Figure 1 Changing the backup name
- CBR automatically adds the autobk_ prefix for you to differentiate automatic backups from manual backups. You are advised to retain the autobk_ prefix.
- CBR can differentiate automatic backups from manual backups no matter you delete the prefix or not. Automatic backups expire based on the retention rule of the backup policy.
- Enter a name and click
. Then, you can view the new backup name in the backup list.
