Project and Enterprise Project
Create a Project and Assign Permissions
- Creating a project
Log in to the management console, click the username in the upper right corner, and select Identity and Access Management from the drop-down list box. In the navigation pane on the left, choose Projects. In the right pane, click Create Project. On the displayed Create Project page, select a region and enter a project name.
- Assigning permissions
You can assign permissions (of resources and operations) to user groups to associate projects with user groups. You can add users to a user group to control projects users can access and the resources on which users can perform operations. The procedure is as follows:
- On the User Groups page, locate the target user group and click Configure Permission in the Operation column. The User Group Permissions page is displayed. Locate the row that contains the target project, click Configure Policy, and select the required policies for the project.
- On the Users page, locate the target user and click Modify in the Operation column. In the User Groups area, add a user group for the user.
Create an Enterprise Project and Assign Permissions
- Creating an enterprise project
On the management console, click Enterprise in the upper right corner. The Enterprise Management page is displayed. In the navigation pane on the left, choose Enterprise Project Management. In the right pane, click Create Enterprise Project and enter a name.
Enterprise is available on the management console only if you have enabled the enterprise project or your account is the primary account. To enable this function, contact your customer manager.
You can add a user group to an enterprise project and configure a policy to associate the enterprise project with the user group. You can add users to a user group to control projects users can access and the resources on which users can perform operations. The procedure is as follows:
- Locate the row that contains the target enterprise project, click More in the Operation column, and select View User Group. On the displayed User Groups page, click Add User Group. In the displayed Add User Group dialog box, select the user groups you want to add and move them to the right pane. Click Next and select the policies.
- In the navigation pane on the left, choose Personnel Management > User Management. Locate the row that contains the target user, click More in the Operation column, and select Add to User Group. In the displayed Add to User Group dialog box, select the user groups for which policies have been configured and click OK.
- Associating BMSs with enterprise projects
You can manage BMSs by enterprise project. To associate BMSs with enterprise projects, perform the following operations:
- Select an enterprise project when buying a BMS.
On the page for buying a BMS, select an enterprise project from the Enterprise Project drop-down list.
- Add BMSs to an enterprise project.
On the Enterprise Project Management page, you can add existing BMSs to an enterprise project.
default indicates the default enterprise project. Resources that are not allocated to any enterprise projects under your account are listed in this project.
For more information, see Enterprise Management User Guide.
