Overview
The following table lists the functions provided by DLI, such as decode1, javahash, and max_pt.
Function |
Syntax |
Value Type |
Description |
decode1(<expression>, <search>, <result>[, <search>, <result>]...[, <default>]) |
Data type of the argument |
Implements if-then-else branch selection. |
javahash(string a) |
STRING |
Returns a hash value. |
max_pt(<table_full_name>) |
STRING |
Returns the name of the largest level-1 partition that contains data in a partitioned table and reads the data of this partition. |
ordinal(bigint <nth>, <var1>, <var2>[,...]) |
DOUBLE or DATETIME |
Sorts input variables in ascending order and returns the value at the position specified by nth. |
trans_array (<num_keys>, <separator>, <key1>,<key2>,…,<col1>,<col2>,<col3>) as (<key1>,<key2>,...,<col1>, <col2>) |
Converts an array split by a fixed separator in a column into multiple rows. |
trunc_numeric(<number>[, bigint<decimal_places>]) |
DOUBLE or DECIMAL |
Truncates the number value to a specified decimal place. |
url_decode(string <input>[, string <encoding>]) |
STRING |
Converts a string from the application/x-www-form-urlencoded MIME format to regular characters. |
url_encode(string <input>[, string <encoding>]) |
STRING |
Encodes a string in the application/x-www-form-urlencoded MIME format. |
