url_decode
This function is used to convert a string from the application/x-www-form-urlencoded MIME format to regular characters.
Syntax
url_decode(string <input>[, string <encoding>])
Parameters
        Parameter  |
        Mandatory  |
        Type  |
        Description  |
        input  |
        Yes  |
        STRING  |
        String to be entered  |
        encoding  |
        No  |
        STRING  |
        Encoding format. Standard encoding formats such as GBK and UTF-8 are supported. If this parameter is not specified, UTF-8 is used by default.  |
Return Values
The return value is of the STRING type.
   UTF-8-encoded string of the STRING type
Example Code
The value Example for URL_DECODE:// dsf (fasfs) is returned.
select url_decode('Example+for+url_decode+%3A%2F%2F+dsf%28fasfs%29', 'GBK');
