javahash
This function is used to return the hash value of a.
Syntax
javahash(string a)
Parameters
| Parameter | Mandatory | Type | Description |
| a | Yes | STRING | Data whose hash value needs to be returned |
Return Values
The return value is of the STRING type.
The hash value is returned. If the value of a is null, an error is reported.
Example Code
The value 48690 is returned.
select javahash("123"); The value 123 is returned.
select javahash(123);
