Updated on 2025-01-09 GMT+08:00
DROP TABLE
Function
This command deletes an existing table.
Syntax
DROP TABLE[IF EXISTS] [db_name.]table_name;
Parameter Description
Table 1 Parameter descriptions of DROP TABLE
db_name
Database name. If not specified, the current database is selected.
table_name
Name of the table to be deleted.
Required Permissions
  • SQL permissions
    Table 2 Permissions required for executing DROP TABLE
    Permission Description
    DROP_TABLE permission on the database where the table is
  • Fine-grained permission: dli:table:dropTable
  • Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
Examples
DROP TABLE IF EXISTS db0.delta_table0;
System Response
The table is successfully deleted from the metadata and cannot be found using show and describe.
