CREATE TABLE
Function
This command creates a Delta table by specifying a list of fields with table attributes.
Precautions
- In this command, IF EXISTS and db_name are optional.
- In DLI, Delta only supports OBS foreign tables. Creating a table using a table name without specifying the location will fail.
Syntax
- Create a Delta table by table name.
CREATE[ OR REPLACE] TABLE [ IF NOT EXISTS] [database_name.]table_name
[ (columnTypeList)]
USING DELTA
[ COMMENT table_comment ]
[ PARTITIONED BY (partColumnList) ]
LOCATION location_path
- Create a Delta table by delta.'Obs path'.
CREATE[ OR REPLACE] TABLE [ IF NOT EXISTS] DELTA.`obs://bucket_name/tbl_path`
[ (columnTypeList)]
USING DELTA
Creating a table by table name allows the table to be found with show tables. In the current version, the location must be specified and can only be set to an OBS path. Creating a table by delta.'Obs path' means the table cannot be found with show tables.
Parameter Description
Parameter |
Description |
database_name |
Name of the database, consisting of letters, numbers, and underscores (_) |
table_name |
Name of the table in the database, consisting of letters, numbers, and underscores (_) |
bucket_name |
Name of the OBS bucket |
tbl_path |
Storage location of the Delta table in the OBS bucket |
columnTypeList |
Comma-separated list with data types. Column names consist of letters, numbers, and underscores (_). |
using |
Parameter delta, defines and creates the Delta table |
table_comment |
Description of the table |
partColumnList |
List of partition fields, with column names from columnTypeList |
location_path |
Storage location of the Delta table. In the current version, it must be specified and can only support OBS paths. Specifying this path creates the Delta table as a foreign table. |
Required Permissions
- SQL permissions
Table 2 Permissions required for executing CREATE TABLE Permission Description
CREATE_TABLE permission on the database
- Fine-grained permission: dli:database:createTable
- Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
Examples
- Create a non-partitioned table by table name.
create table if not exists delta_table0 ( id int, name string, addr struct<priv:string,city:string>, price double ) using delta location 'obs://bucket_name0/db0/delta_table0';
- Create a partitioned table by table name.
create table if not exists delta_table0 ( id bigint, name string, ts bigint, dt string, hh string ) using delta partitioned by (dt, hh) location 'obs://bucket_name0/db0/delta_table0';
- Create a non-partitioned table by delta path.
create table if not exists delta.`obs://bucket_name0/db0/delta_table0`( id int, name string, price double ) using delta;
- Create a partitioned table by delta path.
create table if not exists delta.`obs://bucket_name0/db0/delta_table0` ( id bigint, name string, ts bigint, dt string, hh string ) using delta partitioned by (dt, hh);
- Create a table using create table like.
create table delta_table2 like delta_table1 using delta location 'obs://bucket_name0/db0/delta_table2';
System Response
Displays the successful creation of the table.
