DESCRIBE
Function
This command shows detailed information or statistics about a table.
Syntax
Show statistics about a table:
DESCRIBE [EXTENDED|FORMATTED] [database_name.]table_name|DELTA.`obs://bucket_name/tbl_path`;
Show detailed information about a table:
DESCRIBE DETAIL [database_name.]table_name|DELTA.`obs://bucket_name/tbl_path`;
Required Permissions
- SQL permissions
Permission Description |
DESCRIBE_TABLE permission on a table |
- Fine-grained permission: dli:table:describeTable
- Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
Examples
DESCRIBE FORMATTED delta_table0; DESCRIBE FORMATTED delta.`obs://bucket_name0/db0/delta_table0`; DESCRIBE DETAIL delta_table0;
System Response
Returns details or statistics about a table.
Parameter |
Description |
format |
Format of the table, which is delta in this example |
id |
Unique ID of the table |
name |
Table name defined in MetaServer |
description |
Description about the table |
location |
Storage path of the table |
createdAt |
Timestamp when the table was created |
lastModified |
Timestamp when the table was last modified |
partitionColumns |
Partition column |
numFiles |
Number of files in the latest version of the table |
sizeInBytes |
Size of the latest snapshot of the table, in bytes |
properties |
All the attributes set for this table |
minReaderVersion |
Earliest reader version that can read the table |
minWriterVersion |
Earliest writer version that can write the table |
