CCE AI Assistant
Huawei Cloud CCE is a pivotal platform for enterprise-level containerized deployment. It is for users with extensive technical expertise. To simplify and enhance the usage of cloud container services, CCE AI assistant leverages the Pangu models and DeepSeek technology to establish a comprehensive intelligent support system covering the entire service lifecycle. From initial interaction to advanced application of CCE, the AI assistant offers intelligent support at every stage. It employs interactive Q&A to identify and analyze the core principles and the value proposition of containerized deployment. When selecting solutions, the AI assistant intelligently recommends a cluster configuration based on your service requirements. In O&M management, it provides real-time performance optimization recommendations and fault diagnostics, using core data from cloud platforms and a vast cluster O&M knowledge graph. The key strength lies in its integration of real-time Huawei Cloud control plane status data, cross-industry best practices, and an ever-evolving cloud service knowledge base. This integration allows the AI assistant to offer intelligent decision-making support across architecture design, resource scheduling, and troubleshooting processes. It simplifies enterprise container cloud service utilization and O&M management.
Highlights
CCE AI assistant is built on cutting-edge LLM technologies like Pangu models and DeepSeek. It provides you with a comprehensive AI-driven service center with a unified intelligent assistant. There are the following main highlights:
- Accurate, reliable intelligent suggestions: Leveraging advanced models like Pangu and the inference capabilities of DeepSeek, CCE AI assistant uses Huawei Cloud Standard Operating Procedure (SOP) to provide expert-level solutions to complex problems. Through real-time parsing and semantic association with hundreds of Huawei Cloud services and knowledge graphs spanning thousands of resource types, it avoids common foundation model hallucinations. This ensures precise, contextually coherent suggestions tailored to each issue.
- Comprehensive security and compliance assurance: All operations are designed and meticulously reviewed to adhere to the highest security standards. The AI assistant incorporates enterprise-level security policies and historical behavior data to deliver suggestions customized to specific cloud environments. Every operation is permission-controlled. They require user authorization to guarantee cloud environment security and service reliability.
- Lifecycle-wide, one-stop services: From initial exploration of Huawei Cloud services to product selection and purchase, project startup, routine O&M, and fault recovery, CCE AI assistant offers end-to-end support. By seamlessly transforming intention into action, whether through natural language understanding or automating tasks like Kubernetes cluster operations and log analysis, it ensures efficient, intelligent services at every phase.
Basic Functions
Huawei Cloud CCE AI Assistant Interaction Best Practices
Huawei Cloud CCE AI assistant interacts with you using natural language to efficiently solve various problems. To maximize its functionality, consider the best practices described here. Asking questions more clearly and precisely helps you obtain effective solutions faster. With its strong inference capabilities and automatic diagnostic tools, the Huawei Cloud CCE AI assistant can explore, identify, and analyze problems autonomously. As a result, complex prompts are largely unnecessary. The key is to narrow the scope of the problem, so the assistant can concentrate on the core issue. This reduces the number of operations needed to locate the fault.
