Cluster Types
| Type |
| Positioning | Standard clusters that provide highly reliable and secure containers for commercial use | Next-generation clusters designed for Cloud Native 2.0, with accelerated compute, networks, and scheduling | Serverless clusters without user nodes, no node deployment, management, and security maintenance, billed by actual CPU and memory usage |
| Application scenario | For users who expect to use container clusters to manage applications, obtain elastic compute resources, and enable simplified management on compute, network, and storage resources | For users who have higher requirements on performance, resource utilization, and full-scenario coverage | For users whose services suffer frequent traffic surges, such as users in the online education and e-commerce sectors |
| Network model | Cloud native 1.0 networks: for scenarios where requirements on performance are not high and there are not so many containers
| Cloud Native 2.0 networks: for scenarios where requirements on performance are high and there are many containers A maximum of 2000 nodes is supported. | Cloud Native 2.0 networks: for scenarios where requirements on performance are high and there are many containers |
| hostPort | Supported | Not supported | Not supported |
| Network performance | The container network is overlaid with the VPC network, causing certain performance loss. | The VPC network and container network are flattened into one for zero performance loss. | The VPC network and container network are flattened into one for zero performance loss. |
| Network isolation |
| Pods can be associated with security groups for isolation. This isolation policy, based on security groups, ensures consistent security isolation both within and outside a cluster. | Pods can be associated with security groups for isolation. This isolation policy, based on security groups, ensures consistent security isolation both within and outside a cluster. |
| Container resource isolation | cgroups are used to isolate common containers. |
| VM-level isolation |
| Edge infrastructure management | Not supported | Management of CloudPond edge sites | Not supported |
