Updated on 2026-10-27 GMT+08:00
Cluster List Monitoring Metrics
CPU Metrics
- Total CPUs: the total number of CPU cores across all worker nodes in the cluster (including available and unavailable nodes), calculated based on node specifications.
- Available CPUs: the total number of CPU cores across all available worker nodes in the cluster, calculated based on node specifications.
- Used CPUs: the total number of CPU cores currently used by all available worker nodes in the cluster.
- CPU Usage: Used CPUs of all available worker nodes in the cluster/Available CPUs
Memory Metrics
- Total Memory: the total memory capacity across all worker nodes in the cluster (including available and unavailable nodes), calculated based on node specifications.
- Available Memory: the total memory capacity across all available worker nodes in the cluster (excluding memory occupied by the OS kernel).
For details about memory occupied by the OS kernel, see Why Is the Memory of an ECS Obtained by Running the free Command Inconsistent with the Actual Memory?
- Used Memory: the total memory used by all available worker nodes in the cluster.
- Memory Usage: Used Memory of all available worker nodes in the cluster/Available Memory
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
