Setting Purchase Restriction and Budget Setting Permissions for Resellers
As a distributor, you can grant your resellers the permissions to set budgets, restrict purchases, and restrict purchases and freeze resources for their customers, and allocate the resellers a monthly budget quota and/or one-time budget quota. After the permissions are granted to resellers, you will no longer be responsible for purchase restriction or budget setting of the resellers' customers. When a reseller sets monthly or one-time budgets for their customers, the budgets cannot exceed the budget quota you granted.
In addition, you can revoke these permissions. After the permissions are revoked, resellers will no longer be able to set budgets, restrict purchases, and restrict purchases and freeze resources for their customers. However, the customer budgets already granted will not be automatically canceled. You can adjust customer budgets on the Sales > Customers > Customer Management > Resellers' Customers page in Partner Center.
- A monthly budget reflects the total expenditures (calculated based on the list prices) of a customer the latest month. The budget will restore in the following month. If you set only monthly budget quotas for associated resellers, these resellers can only set monthly budgets for their own customers. For details about how a Huawei Cloud reseller sets monthly budgets for their customers, see Setting Monthly Budgets for Customers.
- A one-time budget reflects the total expenditures (calculated based on the list prices) of a customer. It will not automatically restore. If you set only one-time budget quotas for associated resellers, these resellers can only set one-time budgets for their own customers. For details about how a reseller sets one-time budgets for their customers, see Setting One-Time Budgets for Customers.
- If you set both monthly and one-time budget quotas for your resellers, these resellers can set monthly or one-time budgets for their own customers. The two budget modes can be switched.
- You can grant a monthly budget quota, a one-time budget quota, or both to a reseller based on the actual needs. If a customer of your reseller uses the monthly budget, you need to grant a monthly budget quota to the reseller by default. If a customer of your reseller uses the one-time budget, you need to grant a one-time budget quota to the reseller by default.
- Go to the Reseller Management page.
a) Log in to Huawei Cloud as a distributor.
b) Click Partner Center in the drop-down list of your account name in the upper right corner.
c) In the top navigation, choose Sales > Resellers > Reseller Management.
- Click Purchase Restriction and Budget Setting Permissions in the Operation column for the target reseller.
- You can search for a reseller by reseller name, mobile number, email address, or account manager name.
- You can filter resellers using
in the columns related to association time, whether purchase restriction and budget setting permissions are authorized, and whether the permissions for placing orders and performing O&M on behalf of customers are authorized.
- Toggle on
next to Authorize Permissions to grant permissions. Select at least one budget type and set a monthly budget quota, a one-time budget quota, or both. Click OK.
- You can click Adjustment Records to view the authorization and budget setting records.
- In the displayed dialog box, enter the verification code and click OK to finish the authorization.
- After the authorization is successful, you can access the Purchase Restriction and Budget Setting Permissions page to adjust the budget quotas if necessary.
- A budget quota after adjustment must be greater than or equal to the total budget the reseller set for their customers.
Other Operations
- Revoking permissions
Click Purchase Restriction and Budget Setting Permissions in the Operation column for the target reseller. Toggle off
next to Authorize Permissions to cancel the authorization. In the displayed dialog box, enter the verification code and click OK.
