هذه الصفحة غير متوفرة حاليًا بلغتك المحلية. نحن نعمل جاهدين على إضافة المزيد من اللغات. شاكرين تفهمك ودعمك المستمر لنا.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Show all
Drill Report
Creating a Drill Report
Once a drill is finished, you can create a drill report.
- Log in to COC.
- In the navigation pane on the left, choose Resilience Center > Chaos Drill. On the displayed page, click the Drill Tasks tab.
Figure 1 Drill tasks
- Locate the target drill task and click Drill Record in the Operation column. In the displayed drill record list, locate a desired drill record, click View Report or View Progress in the Operation column. On the displayed Drill Record Detail page, click Generate Drill Report on the right.
Figure 2 Drill record listFigure 3 Drill Record Detail page
- On the displayed Drill Report page and update the report name.
Figure 4 Drill report details
- On the drill report page, enter the drill duration and click OK.
Figure 5 Modifying drill duration
- On the drill report page, click Create Improvement Task, enter information about the improvement item, and click OK to save the created improvement ticket. For details about the follow-up handling of improvement ticket, see Improvement Management.
Figure 6 Creating Improvement Item
Table 1 Improvement ticket parameters Parameter
Improvement Task
Improvement task name
Application
Application to which the improvement task belongs
Type
Type of the improvement task
Improvement Owner
Owner of the improvement task
Expected Completion
Expected completion time of the improvement task
Symptom
Symptom
Improvement Ticket Closure Criteria
Criteria for the closure of the improvement ticket
- On the Drill Report page, click the Fault Record tab to view fault records.
Figure 7 Fault record
