هذه الصفحة غير متوفرة حاليًا بلغتك المحلية. نحن نعمل جاهدين على إضافة المزيد من اللغات. شاكرين تفهمك ودعمك المستمر لنا.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Help Center/
Cloud Operations Center/
User Guide/
Automated O&M/
Script Management/
Managing Custom Scripts
The custom script modification and deletion capabilities are provided.
Modify and delete a custom script to be executed on COC.
Precautions
Confirm and complete the risk level of the script content when modifying a script.
- Log in to COC.
- In the navigation pane on the left, choose Resource O&M > Automated O&M. In the Routine O&M area, click Scripts.
Figure 1 Script management
- Select the operation to be performed on the script.
- To modify a script, click Modify in the Operation column. You can modify the script based on instructions in Creating a Custom Script. To cancel the modification, click Cancel.
- To delete a script, click Delete in the Operation column.
- To review a script, click Review.
Figure 2 Modify, Delete, and Review buttons
Parent topic: Script Management
