Help Center/ Cloud Operations Center/ User Guide/ COC Enablement/ Enabling COC in Batches for Member Accounts
Updated on 2026-11-24 GMT+08:00
In an enterprise cloud environment, O&M personnel often need to enable COC for multiple member accounts for unified management, centralized monitoring, and service collaboration. However, the traditional manual enabling mode is time-consuming and may cause exceptions due to misoperations (such as missing configurations and incorrect parameter settings), which severely affects the O&M efficiency.
By adopting the method of batch enabling COC for multiple member accounts, this pain point can be effectively addressed. It improves service enabling efficiency by switching from the one-by-one operation method to batch operation method. Besides, standardized batch operation processes minimize random errors caused by human misoperations, ensuring that all member accounts have consistent and compliant service configurations. This not only reduces the fault tolerance costs for O&M but also lays a solid foundation for large-scale account management and monitoring in the future.
  • Resource Formation Service (RFS) has been enabled, and the resource stack set quota is sufficient.
  • The Organizations service has been enabled.
  • The organization administrator has enabled COC and RFS as trusted services in Organizations. For details, see Enabling a Trusted Service.
  • The organization administrator has created member accounts or invited accounts to join the organization in Organizations. For details, see Creating a Member Account.
This function applies only to the following scenarios:
  • As an organization administrator, an IAM user enables COC for its member accounts in batches.
  • As a delegated administrator of trusted services, an IAM user enables COC for its member accounts in batches.
  • An IAM Identity Center user enables COC for its member accounts in batches.
  • An IAM SSO user enables COC for member accounts in batches.
  1. Log in to COC.
  2. On the Overview page of COC, check the information in the Quick Configuration Center area.
  3. Choose Cloud O&M Configurations > Business configuration.
  4. Click Batch Activate COC.
    Figure 1 Batch enabling COC for member accounts
  5. In the dialog box displayed on the right, select the account for which you want to enable this service, and click OK.
    Figure 2 Selecting accounts
  6. In the dialog box that is displayed, select You have read and agree to the Cloud Operations Center (COC) Service Statement and click Agree to authorize and enable the service.
    Figure 3 Authorization page
  7. After the service is enabled, you can view the task in by referring to Viewing the Ticket Execution Records of Batch Enabling COC.
After the task of batch enabling COC for multiple accounts is complete, the system automatically generates a quick configuration service ticket to clearly retain the result of new configurations. To follow up on the configured target object and view the configuration result, you can use the ticket query function of the quick configure center module to obtain related details.
  1. Log in to COC.
  2. In the navigation pane, choose Task Management > Execution Records.
  3. Click Quick Configuration Ticket and click Batch Account Activation. The Batch Account Activation tab page is displayed.
    Figure 4 Viewing ticket records
  4. Click the ID of the service ticket you want to view. The service ticket details page is displayed.
