更新时间:2025-12-09 GMT+08:00
错误码
在调用MaaS部署的模型服务时,可能出现的错误码及相关信息如下。
表1 错误码
HTTP状态码
错误码
错误信息
说明
400
ModelArts.81001
Invalid request body.
解析body体失败,如JSON格式化失败、model参数为空。
400
ModelArts.81002
Failed to get the authorization header.
请求头中Authorization为空,或者Authorization格式不是Bearer开头。
400
ModelArts.81013
Content moderation failed when detecting language. The prompt can only contain Chinese.
使用非中文请求,内容审核失败。
400
"object": "error"
"object": "error",
"message": "[{'type': 'missing', 'loc': ('body', 'model'), 'msg': 'Field required', 'input': {'max_tokens': 20, 'messages': [{'role': 'system', 'content': 'You are a helpful assistant.'}, {'role': 'user', 'content': '你好'}], 'stream': False, 'temperature': 1.0}}]",
"type": "BadRequestError",
"param": null,
"code": 400
请求体中缺失必填参数。
400
"object": "error"
"object": "error",
"message": "[{'type': 'extra_forbidden', 'loc': ('body', 'test'), 'msg': 'Extra inputs are not permitted', 'input': 15}]",
"param": null,
"code": 400
请求体中包含不支持的额外请求参数。
400
"object": "error"
"object": "error",
"message": "[{'type': 'json_invalid', 'loc': ('body', 273), 'msg': 'JSON decode error', 'input': {}, 'ctx': {'error': \"Expecting ',' delimiter\"}}]",
"param": null,
"code": 400
请求体json格式错误。
400
"object": "error"
"object": "error",
"message": "[{'type': 'missing', 'loc': ('body',), 'msg': 'Field required', 'input': None}]",
"param": null,
"code": 400
无请求体。
400
"object": "error"
"object": "error",
"message": "This model's maximum context length is 4096 tokens. However, you requested 8242 tokens (20 in the messages, 8222 in the completion). Please reduce the length of the messages or completion.",
"param": null,
"code": 400
max_tokens设置超出模型支持的上限。
401
ModelArts.81003
Invalid authorization header.
API Key解析失败。
403
ModelArts.81004
Invalid request because you do not have access to it.
未开通预置服务。
403
ModelArts.81005
The free quota has been used up.
免费额度已用完。
403
ModelArts.81006
The resource is frozen.
常驻模型已冻结。
403
ModelArts.81011
May contain sensitive.....
输入或者非流式输出风控。
403
ModelArts.81014
The free service has expired. You can subscribe commercial service.
免费服务已到期。
403
ModelArts.81109
No permission query task %s
无权限查询此任务。
404
ModelArts.81009
Invalid model.
请求体中的model参数传入的模型不存在。
404
ModelArts.81108
Task %s does not exist
任务不存在。
404
"object": "error"
"object": "error",
"message": "The model `Qwen2.5-72B-32K` does not exist.",
"type": "NotFoundError",
"param": null,
"code": 404
请求体中model参数填写错误。
404
APIG.0101
"error_msg": "The API does not exist or has not been published in the environment",
"error_code": "APIG.0101",
"request_id": "d0ddda0fcdd0cc23a1588fafe426****"
请求接口地址错误或不存在。
405
"detail":"Method Not Allowed"
采用了错误的请求方式。
429
ModelArts.81101
Too many requests, exceeded rate limit is {rpm} times per minute.
RPM流控校验失败。
429
ModelArts.81103
Too many requests. exceeded rate limit is %s tokens per minute.
TPM流控校验失败。
429
APIG.0308
"error_msg": "The throttling threshold has been reached: policy ip over ratelimit,limit:5,time:1 minute"
达到APIG流量控制上限。
5XX
APIG.0203
"error_msg":"Backend timeout",error_code:APIG.0203
请求的服务响应超时。
