更新时间:2026-09-08 GMT+08:00
LakeFormation资源权限支持列表与策略项
LakeFormation SQL资源权限支持列表
DLI支持SQL资源鉴权的操作列表请参考数据权限列表。
LakeFormation SQL资源权限支持列表请参考表1。
表1 LakeFormation SQL资源权限支持列表
资源类型
权限类型
Database
ALL
ALTER
DROP
DESCRIBE
LIST_TABLE
LIST_FUNC
CREATE_TABLE
CREATE_FUNC
Table/View
ALL
ALTER
DROP
DESCRIBE
UPDATE
INSERT
SELECT
DELETE
Column
SELECT
Function
ALL
ALTER
DROP
DESCRIBE
EXEC
LakeFormation权限策略(Spark)
表2 LakeFormation权限策略
类型
SQL语句
元数据IAM鉴权权限
SQL资源鉴权权限
DDL语句
ALTER DATABASE
database:describe
database:alter
database:DESCRIBE
database:ALTER
ALTER TABLE
database:describe
table:describe
table:alter
database:create
database:DESCRIBE
table:DESCRIBE
table:ALTER
database:CREATE_TABLE
column:SELECT或table:SELECT
ALTER VIEW
database:describe
table:describe
table:alter
database:DESCRIBE
table:DESCRIBE
column:SELECT
table:ALTER
CREATE DATABASE
database:describe
database:create
database:DESCRIBE
catalog:CREATE_DATABASE
CREATE OR REPLACE FUNCTION (CREATE)
database:describe
function:create
database:DESCRIBE
database:CREATE_FUNC
CREATE OR REPLACE FUNCTION (REPLACE)
database:describe
function:describe
function:alter
database:DESCRIBE
function:DESCRIBE
function:ALTER
CREATE TABLE
database:describe
table:describe
table:create
database:DESCRIBE
CREATE VIEW
database:describe
table:describe
table:drop
table:create
table:DESCRIBE(source\target)
table:DROP(target)
column:SELECT
DROP DATABASE
database:describe
database:drop
database:DESCRIBE
database:DROP
DROP FUNCTION
database:describe
function:describe
function:drop
database:DESCRIBE
function:DESCRIBE
function:DROP
DROP TABLE
database:describe
table:describe
credential:describe
table:drop
database:DESCRIBE
table:DESCRIBE
table:DROP
DROP VIEW
database:describe
table:describe
table:drop
database:DESCRIBE
table:DESCRIBE(target\source)
table:DROP(target)
REPAIR TABLE
database:describe
table:describe
credential:describe
table:alter
database:DESCRIBE
table:DESCRIBE
table:ALTER
table:SELECT
TRUNCATE TABLE
database:describe
table:describe
table:alter
database:DESCRIBE
table:DESCRIBE
table:SELECT
table:UPDATE
DML语句
INSERT TABLE
database:describe
table:describe
table:alter
credential:describe
database:DESCRIBE
table:DESCRIBE
table:ALTER
table:INSERT
LOAD DATA
database:describe
table:describe
credential:describe
database:DESCRIBE
table:DESCRIBE
table:UPDATE
table:ALTER
table:SELECT
DR语句
SELECT
database:describe
table:describe
credential:describe
database:DESCRIBE
table:DESCRIBE
column:SELECT
EXPLAIN
取决于执行sql
取决于执行sql
Auxiliary 语句
ANALYZE TABLE
database:describe
table:describe
credential:describe
table:alter
database:DESCRIBE
table:DESCRIBE
table:SELECT
table:ALTER
DESCRIBE DATABASE
database:describe
database:DESCRIBE
DESCRIBE FUNCTION
database:describe
function:describe
database:DESCRIBE
function:DESCRIBE
DESCRIBE QUERY
database:describe
table:describe
database:DESCRIBE
table:DESCRIBE
table:SELECT
DESCRIBE TABLE
database:describe
table:describe
database:DESCRIBE
table:DESCRIBE
REFRESH TABLE
database:describe
table:describe
credential:describe
database:DESCRIBE
table:DESCRIBE
table:SELECT
REFRESH FUNCTION
database:describe
function:describe
database:DESCRIBE
function:DESCRIBE
SHOW COLUMNS
database:describe
table:describe
database:DESCRIBE
table:DESCRIBE
SHOW CREATE TABLE
database:describe
table:describe
database:DESCRIBE
table:DESCRIBE
SHOW DATABASES
database:describe
catalog:LIST_DATABASE
database:DESCRIBE
SHOW FUNCTIONS
database:describe
function:describe
database:DESCRIBE
SHOW PARTITIONS
database:describe
table:describe
database:DESCRIBE
table:DESCRIBE
SHOW TABLE EXTENDED
database:describe
table:describe
database:DESCRIBE
table:DESCRIBE
database:LIST_TABLE
SHOW TABLES
database:describe
table:describe
database:LIST_TABLE
database:DESCRIBE
SHOW TBLPROPERTIES
database:describe
table:describe
database:DESCRIBE
table:DESCRIBE
SHOW VIEWS
database:describe
table:describe
database:LIST_TABLE
database:DESCRIBE
