更新时间:2024-01-04 GMT+08:00
Pod接口ExtendPathMode: PodUID如何与社区client-go兼容?
使用场景
社区Pod结构体中没有ExtendPathMode,用户使用client-go调用创建pod或deployment的API接口时,创建的pod中没有ExtendPathMode。为了与社区的client-go兼容,CCE提供了如下解决方案。
解决方案
- 创建pod时,在pod的annotation中需增加kubernetes.io/extend-path-mode。
- 创建deployment时,需要在template中的annotation增加kubernetes.io/extend-path-mode。
如下为创建pod的yaml示例,在annotation中添加kubernetes.io/extend-path-mode关键字后,完全匹配到containername,name,mountpath三个字段,则会在volumeMount中增加对应的extendpathmode:
apiVersion: v1
kind: Pod
generateName: test-8b59d5884-
namespace: default
selfLink: /api/v1/namespaces/default/pods/test-8b59d5884-96vdz
labels:
app: test
pod-template-hash: 8b59d5884
annotations:
kubernetes.io/extend-path-mode: '[{"containername":"container-0","name":"vol-156738843032165499","mountpath":"/tmp","extendpathmode":"PodUID"}]'
metrics.alpha.kubernetes.io/custom-endpoints: '[{"api":"","path":"","port":"","names":""}]'
ownerReferences:
- apiVersion: apps/v1
kind: ReplicaSet
uid: 2633020b-cd23-11e9-8f83-fa163e592534
controller: true
blockOwnerDeletion: true
volumes:
- name: vol-156738843032165499
hostPath:
path: /tmp
type: ''
- name: default-token-4s959
secret:
secretName: default-token-4s959
defaultMode: 420
containers:
- name: container-0
image: 'nginx:latest'
env:
- name: PAAS_APP_NAME
value: test
- name: PAAS_NAMESPACE
value: default
- name: PAAS_PROJECT_ID
value: b6315dd3d0ff4be5b31a963256794989
resources:
limits:
cpu: 250m
memory: 512Mi
requests:
cpu: 250m
memory: 512Mi
volumeMounts:
mountPath: /tmp
extendPathMode: PodUID
readOnly: true
mountPath: /var/run/secrets/kubernetes.io/serviceaccount
terminationMessagePath: /dev/termination-log
terminationMessagePolicy: File
imagePullPolicy: Always
restartPolicy: Always
terminationGracePeriodSeconds: 30
dnsPolicy: ClusterFirst
serviceAccountName: default
serviceAccount: default
nodeName: 192.168.0.24
securityContext: {}
imagePullSecrets:
- name: default-secret
affinity: {}
schedulerName: default-scheduler
tolerations:
- key: node.kubernetes.io/not-ready
operator: Exists
effect: NoExecute
tolerationSeconds: 300
- key: node.kubernetes.io/unreachable
operator: Exists
effect: NoExecute
priority: 0
dnsConfig:
options:
- name: timeout
value: ''
- name: ndots
value: '5'
- name: single-request-reopen
enableServiceLinks: true
参数 |
参数类型 |
描述 |
containername |
String |
容器名称。 |
name |
String |
volume的名称。 |
mountpath |
String |
挂载路径 |
extendpathmode |
String |
将在已创建的“卷目录/子目录”中增加一个三级目录,便于更方便获取单个Pod输出的文件。 支持如下五种类型。
父主题: 存储管理
