What's New
The tables below describe the functions released in each Intelligent EdgeFabric version and corresponding documentation updates. New features will be successively launched in each region.
November 2021
No. |
Feature |
Description |
Phase |
Document |
1 |
EdgeCore configuration management |
IEF allows you to manage EdgeCore configuration parameters, through which you can let EdgeCore work under your very requirements. |
Commercial use |
April 2021
No. |
Feature |
Description |
Phase |
Document |
1 |
Updated method of installing the GPU driver on an edge node |
To enable GPUs of an edge node, you only need to copy the driver files to specified directories on the edge node. |
Commercial use |
March 2021
No. |
Feature |
Description |
Phase |
Document |
1 |
Support for Huawei machine vision IVS3800/IVS1800 series products |
Edge devices of the IVS1800/IVS3800 series can access IEF. |
Commercial use |
2 |
Support for Ascend 910 processors |
Ascend 910 processor scheduling and edge computing AI training scenarios are supported. |
Commercial use |
January 2021
No. |
Feature |
Description |
Phase |
Document |
1 |
Edge node software version management |
During edge node upgrade, IEF automatically selects the EdgeCore of the latest version. |
Commercial use |
August 2020
No. |
Feature |
Description |
Phase |
Document |
1 |
Edge gateway capability enhancement |
The edge application mesh IngressGateway supports the WSS and HTTPS protocols. |
Friendly user testing |
July 2020
No. |
Feature |
Description |
Phase |
Document |
1 |
Edge IngressGateway |
The edge application mesh supports IngressGateway, which allows external applications to access edge applications deployed on IEF and can forward traffic based on routing rules. |
June 2020
No. |
Feature |
Description |
Phase |
Document |
1 |
New console style |
The console is restyled to be more concise and easy-to-use. |
Commercial use |
May 2020
No. |
Feature |
Description |
Phase |
Document |
1 |
Platform event subscription |
IEF provides the system subscription function for you to subscribe to IEF resource change events. When a resource is created, updated, or deleted, IEF will send a message to the specified API Gateway endpoint so that you can obtain resource changes in a timely manner. |
Commercial use |
February 2020
No. |
Feature |
Description |
Phase |
Document |
1 |
Support for ConfigMap mounting |
ConfigMaps store configuration details required for workloads. ConfigMaps decouple configuration files from container images to enhance workload portability. |
Commercial use |
January 2020
No. |
Feature |
Description |
Phase |
Document |
1 |
Commercial use of IEF |
IEF is put into commercial use. |
Commercial use |
