What's New
The tables below describe the functions released in each Cloud Firewall version and corresponding documentation updates. New features will be successively launched in each region.
June 2026
| No. | Feature | Description | Phase | Document |
| 1 | Optimization of critical operation confirmations | When you disable a protection rule, delete a protection rule, disable basic protection, or disable virtual patches on the management console, the system displays a risk warning and a confirmation pop-up window to prevent service disruption due to accidental misconfiguration. | Commercial use |
January 2026
| 1 | Resource statistics |
| Commercial use | |
| 2 | Batch export for inactive policies | To simplify rule filtering and routine O&M, you can now export details on inactive policies from the policy assistant. | Commercial use | |
| 3 | Batch export for traffic analysis data | You can now batch-export the following traffic analysis data from the management console as a list:
| Commercial use | |
| 4 | Critical operation protection | The console now supports sensitive operation protection. When this feature is enabled, the system enforces identity authentication during critical actions, such as protection policy deletion, to prevent unauthorized configuration changes. | Commercial use | |
| 5 | Confirmation for virtual patch updates | When you update a virtual patch on the management console, a confirmation dialog box is displayed to prevent accidental misconfigurations from disrupting services. | Commercial use | |
| 6 | Optimized status indicators for inactive policies | On the protection rule page, if a rule has not been matched for a month, the system displays the Inactive status next to the rule name. You can hover over this status to view the rule's match count and its last match time. | Commercial use |
December 2025
| 1 | Optimized policy assistant | The visual layout of the policy assistant has been optimized. The details of inactive policies are now displayed on a dedicated page for easier viewing. | Commercial use | |
| 2 | Optimized traffic analysis | The visual layout of the traffic analysis feature has been optimized, moving relevant metrics to dedicated pages:
| Commercial use |
June 2025
| 1 | Optimized protection rule management | When you add a protection rule, you can configure one or more types in the same rule. The following types can be configured at the same time:
| Commercial use | Configuring Internet Border Protection Rules |
May 2025
| 1 | Traffic blocking | CFW can quickly block attacks from a large number of malicious IP addresses. | Commercial use | |
| 2 | One-click kill switch and one-click restoration | CFW supports the one-click kill switch and one-click restoration functions. You can quickly disable or enable the EIP protection provided by the current firewall. | Commercial use |
July 2024
| 1 | VPC border protection based on domain names | Added domain name access control in VPC border protection. | Commercial use | |
| 2 | DNAT protection | CFW can protect DNAT traffic. | Commercial use | |
| 3 | Schedule | You can configure schedules to make protection rules take effect only within the specified time range. | Commercial use |
March 2024
| 1 | Security reports | CFW can generate daily, weekly, or user-defined security reports based on the log report template you created, and send the reports in the specified mode within the specified period. | Commercial use | |
| 2 | Alarm notification for abnormal external connections | CFW allows you to set alarm notifications for abnormal external connections. If an abnormal IP address or domain name is detected, an alarm notification is sent. | Commercial use |
December 2023
| 1 | Pre-defined address groups | CFW provides you with predefined address groups, including NAT64 Address Set and WAF_Back-to-Source_IP_Addresses, to help you quickly obtain the back-to-source IP addresses to be allowed. | Commercial use | |
| 2 | Pre-defined service groups | CFW provides predefined service groups, including Web Service, Database, and Remote Login and Ping, to help you quickly configure protection policies in different scenarios. | Commercial use |
November 2023
| 1 | Auto protection on new EIPs | After auto protection on new EIPs is enabled, protection will be automatically enabled for new EIPs, and the EIP traffic will pass through and be protected by the firewall. | Commercial use | |
| 2 | Security Dashboard | You can use the policy assistant to quickly check protection rule hits and adjust rules in a timely manner. | Commercial use | |
| 3 | Notification of unprotected EIPs | You can get notified of unprotected EIPs after you enable this alarm notification item. | Commercial use | |
| 4 | Optimized traffic analysis page | Added visualized information about top N inbound, outbound, and inter-VPC traffic statistics on the traffic analysis page. | Commercial use | |
| 5 | Optimized Dashboard page | Optimized the display of traffic statistics and added traffic trends on the Dashboard page. | Commercial use | |
| 6 | Security dashboard | The security dashboard displays the high-frequency attacks blocked by IPS. You can check the IPS defense status and adjust IPS defense actions in a timely manner. | Commercial use |
July 2023
| 1 | Antivirus | The anti-virus function identifies and processes virus files through virus feature detection to prevent data damage, permission change, and system breakdown caused by virus files. | Commercial use |
May 2023
| 1 | Inter-VPC border protection policy import and export | You can import and export inter-VPC border firewall access control policies. | Commercial use | |
| 2 | Sensitive directory scan defense | Defend against scan attacks on sensitive directories in real time. | Commercial use | |
| 3 | Reverse shell defense | Defend against reverse shells. | Commercial use | |
| 4 | Custom IPS signature | You can configure network detection signature rules in CFW. CFW will detect threats in data traffic based on signatures. | Commercial use |
April 2023
| 1 | Network packet capture | You can use the packet capture function to locate network faults and attacks. | Commercial use | |
| 2 | Domain group protection | A domain name group is a collection of multiple domain names or wildcard domain names. You can configure domain name groups to protect domains in batches. | Commercial use |
March 2023
| 1 | User-defined basic defense | You can check the CVE ID, risk level, and attack type of a basic IPS defense rule and modify defense actions. | Commercial use | |
| 2 | CFW professional edition | Internet border protection, Internet ACL, full network traffic analysis, network intrusion prevention system (IPS), inter-VPC traffic protection, and inter-VPC asset protection | Commercial use | |
| 3 | Alarm notification | CFW interconnects with Simple Message Notification (SMN) to send IPS attack logs and excessive traffic warning through the notification method (email or SMS) you set. | Commercial use |
November 2022
| 1 | API calling | APIs can be invoked through the API Explorer. | Commercial use |
August 2022
| 1 | CFW OBT test | Launched the first open beta test (OBT). | -- |
