Verifying an Image Signature
To verify image signatures, you need to install the swr-cosign add-on. This section describes how to install the add-on.
Installing swr-cosign
- Log in to the CCE console.
- In the navigation pane, choose Add-ons.
- In the search box, enter cosign.
- Locate the Container Image Signature Verification add-on in the search result and click Install.
- Set the following parameters:
- Cluster: Select the cluster where the image will be used. Only K8s V1.23 or later clusters are supported.
Before verifying image signatures in a namespace of a cluster, you need to add the policy.sigstore.dev/include:true label for the namespace.
- Version: Select an add-on version.
- Specifications:
- Single: The add-on can be used only in one repository.
- HA: The add-on can be used in two repositories.
- Custom: You can customize the number of repositories, CPU quota, and container quota.
Table 1 swr-cosign specifications Parameter
Add-on Specifications
The value can be Single, HA, or Custom.
Pods
Number of pods that will be created to match the selected add-on specifications.
If you selected Custom for Specifications, you can adjust the number of pods as needed.
If you selected Custom for Specifications, you can adjust the container specifications as needed.
- Parameters
- KMS Key: Select a key created in Creating an Asymmetric Key.
- Signature Verification Image: Click
and select the images whose signatures need to be verified.
Table 2 swr-cosign parameters Parameter
KMS Key
Select a key. Only EC_P256, EC_P384, and SM2 keys are supported.
You can create a key using KMS.
Enter a regular expression. For example, if you enter docker.io/**, the signatures of all the images in the docker.io repository will be verified. To verify the signatures of all images, enter **.
- Click Install.
After the installation is complete, select the cluster and click Add-ons in the navigation pane. On the displayed page, you can see the installed swr-cosign.
Log in to the CCE console and click the name of a cluster where swr-cosign has been installed. In the navigation pane, choose Workloads and click Create Workload. Select a namespace with the policy.sigstore.dev/include:true label and an unsigned image. Select an image access credential and continue to create the workload. The image will fail the signature verification because it has no signature.
